Post by Bazille on Jul 18, 2013 21:44:03 GMT 1
my recently acquired 350 powervalve has an oil pump with 4L1 on pulley-surely this is a 250 lc pump??, what markings oil pump should i look out for?
cheers colin
Post by Deleted on Jul 18, 2013 21:46:18 GMT 1
You have to look how many turns are on the worm of the pump. How many turns have you got as paint not an accurate indicator
Post by Bazille on Jul 18, 2013 22:01:30 GMT 1
I will check in morning for the worm, what do you mean about paint?
Post by wallcraft on Jul 18, 2013 22:35:26 GMT 1
350 has yellow blob of paint on one of the housing screws, 250 has red blob. Bit of a mix regarding 4L1 markings some 350's did have it some did'nt. Maybe Arrow pump expert will come along and put you right.
Post by arrow on Jul 19, 2013 7:07:23 GMT 1
Leave the pump on for now dude. As its a power valve its much more unlikely to have a 250 pump on it. Have a look at my "A word of warning" thread in the tech section. This should put your mind at rest.
Post by Bazille on Jul 19, 2013 9:58:04 GMT 1
Oh maybe it is ok then as there is a small trace of yellow paint on the pump!! thanks arrow will check that out now cheers
phil38
Post by phil38 on Jul 19, 2013 13:23:34 GMT 1
My ypvs has 4L1 stamped on it. It's beek checked by arrow and is all OK (I was wondering about that too)!
Post by arrow on Jul 19, 2013 14:05:57 GMT 1
My ypvs has 4L1 stamped on it. It's beek checked by arrow and is all OK (I was wondering about that too)! The 4L1 pulley is a common part to various pumps.
