Post by hopper350 on Jul 16, 2013 22:33:16 GMT 1
Hi, does anyone know whats the average amount of material on a ypvs flywheel that generally gets machined off the flywheel to lighten it for road use.
Post by muttsnuts on Jul 17, 2013 13:14:48 GMT 1
no more than 6mm, I generally stay conservative and just take 3mm to 4mm off, that way the flywheel doesn't/hasn't to date anyway, produced any cracks etc
Post by icarus001 on Jul 17, 2013 19:49:34 GMT 1
Does it make much difference?
Post by Norbo on Jul 18, 2013 6:22:54 GMT 1
Happer . what muts is talking about is over all depth not normal depth . your not looking at the depth of material taken of 1 side as you may measure but the rad depth
Post by kevsypvs on Jul 18, 2013 10:35:00 GMT 1
what would the finished diameter of the flywheel be ?
Post by wallcraft on Jul 18, 2013 22:41:47 GMT 1
6mm less than what you started with assuming its standard.
stuboy
Post by stuboy on Jul 19, 2013 14:08:19 GMT 1
Just dont miss a gear with a lightened flywheel as the engine revs off the tacho !! Another issue is that you are robbing the engine of momentum with a lightened flywheel. And before there are any replies that is true as I have had lightened flywheels on tuned cars and tuned motorbikes. Good for quick acceleration and blipping at lights but no good for trying to slog up a hill or slog up to a high top speed !! :-).
