Post by ducatidave on Jul 13, 2013 11:33:43 GMT 1
Does any1 get it and wer from (online) halfords don't have it : (
Post by ducatidave on Jul 13, 2013 11:40:02 GMT 1
Found 1 that does castrol racing silly q but does this smell like castrol r ? Same stuf ?
Post by kevsypvs on Jul 13, 2013 12:49:44 GMT 1
castrol r 40 is the same smell dont use a lot in your petrol tank or youl gum up the carbs if using it on your lc/ypvs
Post by ducatidave on Jul 13, 2013 12:53:38 GMT 1
castrol r 40 is the same smell dont use a lot in your petrol tank or youl gum up the carbs if using it on your lc/ypvs Am useing it on its own in oil pump tank is this ok ?
Post by ducatidave on Jul 13, 2013 12:54:43 GMT 1
castrol r 40 is the same smell dont use a lot in your petrol tank or youl gum up the carbs if using it on your lc/ypvs Am useing it on its own in oil pump tank is this ok ? Not in petrol tank
Post by kevsypvs on Jul 13, 2013 13:04:56 GMT 1
no crist you cant use it in the two stroke tank also itl not mix if your using synthetic oil in your oil tank as its castor based all you can do is add a teaspoonfull to a full tank of petrol and run non synthetic oil in your oil tank castrol r is not produced anymore only r40 4 stroke racing oil its too thick to mix in your autolube mate not really for two stroke use
Post by ducatidave on Jul 13, 2013 13:39:32 GMT 1
no crist you cant use it in the two stroke tank also itl not mix if your using synthetic oil in your oil tank as its castor based all you can do is add a teaspoonfull to a full tank of petrol and run non synthetic oil in your oil tank castrol r is not produced anymore only r40 4 stroke racing oil its too thick to mix in your autolube mate not really for two stroke use Ok but halfords has got castrol racing 2stroke oil is this ok ?
Post by ducatidave on Jul 13, 2013 13:45:18 GMT 1
A friend says this stuf smells nice So if castrol r I carnt use then am goin use this
Post by Deleted on Jul 13, 2013 15:31:59 GMT 1
Post by arrow on Jul 13, 2013 16:26:21 GMT 1
The rock oil in the pic is the same as pp2. Doesn't smell that nice IMO. Don't use Castrol R as 2 stroke oil in the tank. If the bike is layed up over winter then come the new season the motor will be all gummed and rusted up.
