Post by 4l04ever on Jul 10, 2013 9:34:32 GMT 1
Trying to find which model TZR125 reed blocks will fit.....
Post by garyt on Jul 10, 2013 9:49:38 GMT 1
Post by midlifecrisisrd on Jul 10, 2013 10:51:19 GMT 1
got a set of tzr 250 6 petal fibre reeds bonded to 10 mm spacers that were in my ypvs.
pic in the for sale section.
steve
Post by nikfubar on Jul 10, 2013 11:16:11 GMT 1
Here's my attempt at fitting 2MA reeds got some 6mm spacers from NK, cut the cages off an old set of reeds & sandwiched the reeds between the two, bonded together with 3bond & the gaps filled with JB weld then sanded down. The finished article ;D
Post by 4l04ever on Jul 10, 2013 14:45:37 GMT 1
Here's my attempt at fitting 2MA reeds got some 6mm spacers from NK, cut the cages off an old set of reeds & sandwiched the reeds between the two, bonded together with 3bond & the gaps filled with JB weld then sanded down. The finished article ;D Nice job. :-) Did you have to open up the inlet to make this fit? Did it give any gain over standard ypvs reeds?
Post by nikfubar on Jul 10, 2013 16:14:49 GMT 1
The 6mm spacer means you don't have to open up the inlet, definitely better than the standard metal reeds.
Post by oldelsieboy on Jul 10, 2013 16:28:53 GMT 1
If you want a pair of 2MA reed blocks fitted with fibre reeds, I have some for sale :-)
OEB
