trog
Post by trog on Jul 8, 2013 21:06:59 GMT 1
got a ypvs n1 and i think it needs bigger jets, its got ram air filters and giannelli exhausts it did have a boost bottle on as well but i'v taken that off cause it was running that bad....... can anybody help with what size jets a should use and are the boost bottles any good, should i just stick with the standard connector pipe
Post by billyboy on Jul 8, 2013 21:12:28 GMT 1
start large with your mains and do a plug chop ,boost bottles are generally fitted to get rid of flat spots, but it wouldn't make it run badly , you must have an other problem , would help if you could say exactly whats happening in the way of poor running
trog
Post by trog on Jul 8, 2013 21:36:04 GMT 1
it will rev and drop revs ok when stood but when riding its real sluggish setting off and the revs dont drop when changing gear....its a n2 not n1
Post by dusty350 on Jul 9, 2013 7:01:52 GMT 1
Hi, If you've got powerjet carbs fitted, they are known for being difficult to set up with pod filters. 31K non powerjets are better with pods. Also K&N style filters with metal end caps are worst than the foam style pods. It's trial and error with settings, but as said, start big and work down.
Dusty
trog
Post by trog on Jul 9, 2013 8:17:08 GMT 1
Thanks for the help............and is it just the main jet a need to swap
Post by yardstikk on Jul 10, 2013 16:49:09 GMT 1
Try a plug chop.. Take it from there..
trog
Post by trog on Jul 10, 2013 17:16:22 GMT 1
What's a plug chop.......
Post by billyboy on Jul 10, 2013 21:16:19 GMT 1
look under the jetting bit of the technical section on this forum for great info
