Post by billyboy on Jul 5, 2013 14:41:18 GMT 1
is it possible to change the big seal behind the sprocket without splitting the cases ? i am not best pleased as my brand new one has failed and the motor has never been ran up
Post by billyboy on Jul 5, 2013 15:43:08 GMT 1
cheers,might be asking the supplier to replace it ,and it aint yambits either
Post by steeley on Jul 5, 2013 18:46:12 GMT 1
best of luck with that.
Post by billyboy on Jul 5, 2013 18:53:17 GMT 1
what the fitting or getting the seal replaced ?
Post by steeley on Jul 6, 2013 5:47:45 GMT 1
getting the seal replaced.as head coats said make sure you get it in square.
Post by billyboy on Jul 7, 2013 16:34:26 GMT 1
sound advice thanks ,its a 2 lip seal and its the outer seal thats gone so might be ok anyhow ,just bloody annoying that its a brand new seal
Post by pepsisteve on Jul 10, 2013 13:44:24 GMT 1
dont forget to check the condition of the steel spacer as that is the part it seals on, with a bit of grease around the outside you should be able to push it in by hand with a bit of force, better than fudging it up with a drift, i fit seals all day by the way......
