Post by hardhatharry on Jul 4, 2013 15:02:18 GMT 1
Ok some of you may know I have had some problems with my loom so after a month or two banging my head I came to the conclusion best get another loom and start again.
Cleaning up the new (to me) loom I noticed its a 1WT loom.
So the configuration has gone from 1UA loom, 1UA ECU, 31K engine which used to work (prior to sticking it into the LC frame to make a hybrid) to 1WT loom, 1UA ECU, 31K engine.
This maybe a blessing in disguise as the 1WT loom is less complicated as I can get rid of the side stand module.
Question is before I start making the new loom fit the frame will this new configuration work?
Thanks all
Post by yardstikk on Jul 10, 2013 17:04:26 GMT 1
Should be possible..
