Post by Taylormade on Jul 3, 2013 21:31:45 GMT 1
Think I may have a small oil leak coming from my gear selector shaft..... I assume there must be a seal somewhere ?? Is this an easy fix??
Post by copper99 on Jul 4, 2013 7:45:50 GMT 1
As I understand it, the shaft wears at a particulary spot,where the seal sits, so sometimes even a new seal wont cure it.
I believe its a case of removing both engine cases, freeing it from the gear change mechanism clutth side and sliding it out.
Mine is also doing the same, just slightly. Going to hold that off for the Winter if I can.
Post by petejw22 on Jul 4, 2013 9:05:32 GMT 1
On LC/YPVS models, remove clutch basket & slide out gear shaft to inspect - if you have a ridge, then it's best to replace it. I believe that norbo sells them. I personally wouldn't try replacing oil seal with shaft in situ.
Post by Taylormade on Jul 4, 2013 22:19:42 GMT 1
On LC/YPVS models, remove clutch basket & slide out gear shaft to inspect - if you have a ridge, then it's best to replace it. I believe that norbo sells them. I personally wouldn't try replacing oil seal with shaft in situ. I've heard this has been done? (Replacing seal with shaft in situ) Anyone else done this??? Thanks for the input
matt7
Post by matt7 on Jul 5, 2013 18:41:53 GMT 1
Check your local bearings supplier, I got oil seals for gearshift - thay are 1mm thinner than standard - the seal sits on a fresh part of the shaft
Post by steeley on Jul 5, 2013 18:44:19 GMT 1
I have still got a leak from this shaft after replacing the shaft and the seal.in the winter I am going to get a grove machined in the shaft for an o ring.will see how that goes .oh 350 lc 4lo.
