peacey
Post by peacey on Jul 2, 2013 16:21:30 GMT 1
Hi all, just wanting to confirm if my powervalves are sticking, when ignition switched on it makes the usual noise but the noise carries on, sounds like somethings sticking, and the bike doesn't want to rev much past 5 grand.
Post by davey on Jul 2, 2013 16:30:19 GMT 1
Sounds like it could be a broken cable mate, i had the same problem with mine . Remove rhe plate that covers the pwr valve pulley and watch if it cycles both ways , if not its bust maybe somwhere in the line Hth
Davey
peacey
Post by peacey on Jul 2, 2013 17:18:00 GMT 1
Just checked the powervalve and cycles both ways? any ideas what else the noise could be?
Post by 47x on Jul 4, 2013 16:49:49 GMT 1
servo on its way out??
Post by hardhatharry on Jul 4, 2013 17:03:31 GMT 1
You can pull the servo apart and regrease it, it fixed mine
Post by hardhatharry on Jul 4, 2013 17:05:22 GMT 1
peacey
Post by peacey on Jul 4, 2013 17:30:55 GMT 1
what did your servo do before you pulled it apart? my servo looks like its fighting against something, twitching away at the end of the cycle it does, when ignition switched on?
paulo
Post by paulo on Jul 4, 2013 17:39:31 GMT 1
Have you checked how free the power valves are ?. Disconnect the cables and see if you can turn the pulley easy by hand.
Post by billyboy on Jul 5, 2013 18:55:22 GMT 1
whip the pipes off and look up inside the exhaust ports to see excatly whats going on would be my starting point
