peacey
Post by peacey on Jul 1, 2013 21:40:06 GMT 1
Hi have an F2 with allspeeds and 1 side is blowing, do allspeeds use gaskets?
Post by Yogi on Jul 1, 2013 22:05:13 GMT 1
I used normal gaskets on mine,but also used putty inside where the collars slide over the pipes, mainly to stop oil leaking down them, works perfect,,,,also when I take them off it keeps the collars in place
peacey
Post by peacey on Jul 1, 2013 22:07:54 GMT 1
Thanks mate will try and fix tomorrow...
Post by Yogi on Jul 1, 2013 22:15:58 GMT 1
Might be worth replacing the the round copper rings that fit in the port as they get squashed after a while
Post by davey on Jul 2, 2013 16:35:14 GMT 1
X2 but i ised instant gasket instead , not a drop of oil leaks now
Post by gazlad on Jul 2, 2013 17:16:42 GMT 1
Silicon sealant works a treat
Post by petejw22 on Jul 3, 2013 9:59:44 GMT 1
Another vote for clear silicon - once set you can remove any excess...
