Post by ashman555 on Jul 1, 2013 7:38:53 GMT 1
Hi guys , just fitted a rgv vj22 swinging arm in a 4lo frame with a 31k motor , it has the offset front sprocket fitted but the chain seems to run very near to the swinging arm is this correct ? O and the swinging arm has been converted by Nk racing .
Post by loctite on Jul 1, 2013 22:27:12 GMT 1
do you mean close to swinging arm or frame,im running 4l0 engine in mine with offset front sprocket I had to use a ypvs spacer behind sprocket slightly deeper than standard 4l0,maybe you need to go the other way and put a 4l0 spacer on,cheers nigel
