phil38
Post by phil38 on Jun 30, 2013 10:59:46 GMT 1
…doesn't feel like it wants to go in any further. It's a tapered thread so I guess it's ok?
Post by midlifecrisisrd on Jun 30, 2013 11:21:19 GMT 1
Yes it is a taper thread on the F2 sender.
31k was straight
Post by steeley on Jun 30, 2013 11:59:07 GMT 1
taper on the thread so they saved on a sealing washer. got a landrover sender for my 350 lc the original one broke.soldered a spade connector on it and it works a treat. 3.30 plus free p@p RST LANDROVERS.
phil38
Post by phil38 on Jun 30, 2013 13:09:57 GMT 1
Yes it is a taper thread on the F2 sender. 31k was straight Steve Does it look normal to you? ( far enough in?)
Post by midlifecrisisrd on Jun 30, 2013 14:15:40 GMT 1
Yes it is a taper thread on the F2 sender. 31k was straight Steve Does it look normal to you? ( far enough in?) Yes, lucky if it goes in half way Steve
phil38
Post by phil38 on Jun 30, 2013 14:30:14 GMT 1
Thanks for that. I though it was ok, but it's been while since I took it out. Nearly there!
Post by parrott500 on Jul 1, 2013 22:18:25 GMT 1
I have 31k my temp sender with spade fitting should be 5R2-83591-00 i found a superseeded part while googleing 17W-83591-00 if this is any use to anyone going up in price £30.52 plus vat now, works fine only difference is the head is a little smaller. Attachment Deleted
Post by cb250g5 on Jul 1, 2013 22:27:15 GMT 1
Post by parrott500 on Jul 1, 2013 22:34:29 GMT 1
I`ll Try one next time.
Cheers.
robw
Post by robw on Jul 2, 2013 7:10:06 GMT 1
Thanks for the eBay link, the terminal on mine is a bit ropey, so i better have one on the shelf. Rob
Post by steve h on Jul 2, 2013 10:14:12 GMT 1
A bit of ptfe tape on the sensor before installation does no harm.
