Post by steelerd on Jun 29, 2013 15:20:12 GMT 1
Hi everyone just a quick q just about to put the carbs back on the lc is there a good way to set the throttle screw up on them? or a certain amount of turns thats usually about right?
thanks,
tom
paulo
Post by paulo on Jun 29, 2013 19:30:52 GMT 1
Hi mate, I use a 4mm drill. Adjust screws until drill will just slip under slide from airbox side - this sets both slides the same. Fit carbs, adjust throttle cable so both slides start to lift at the same time - lollipop stick method. Then equally adjust throttle screws to set tick over speed ie rh carb one turn clockwise, Lhs carb one turn clockwise. Best of luck mate.
Post by arrow on Jun 29, 2013 19:59:45 GMT 1
The final, fine adjustment is done listening to the end of each exhaust pipe so they sound exactly the same.
Post by steelerd on Jun 29, 2013 20:25:46 GMT 1
nice one lads really appreciate it getting close now can't wait
