Post by dave1967 on Jun 29, 2013 2:57:47 GMT 1
I have R1 blue spot brake calipers on my 31k..not sure which master cylinders will fit..i have to get a new one anyway as my original one is knackered..also if i have something like a Fazer 600 or 1000 master cylinder which comes with brake lever does it mean i end up with odd levers as i see the Fazer ones are adjustable??
Post by bare on Jun 29, 2013 3:21:55 GMT 1
Erm.. bit more complex issues than matching levers. You need fit a master with the appropriate sized bore to operate the Calipers to best effect. Sadly even OEM matches are often poor. Especially with Yamaha.. which had (has?) a decades long tradition of oversizing the master resulting in poor (or at least much less than ideal) brake action /feel. Google up a master/caliper sizing ratio chart (they exisat) and choose the appropriate bore size ratio then find /source o real life master cyl to comply. Levers can be swapped much easier :-)
Post by dave1967 on Jun 29, 2013 3:30:14 GMT 1
Ohhh...hmmm...has anyone else on here got the blue spot brakes and if so which master cylinder do you use...nothings ever easy is it..lol
Post by dave1967 on Jun 29, 2013 3:34:57 GMT 1
