Post by The Pirate on Jun 27, 2013 20:08:00 GMT 1
can anyone tell me or show me a picture of where the air jet is on a 1ua carbs,,, im checking all things in the carbs which seem to be wrong for my f2,, and now its the turn to check the air jet but I have no idea what im looking for ............ oh and before a forget a also need to know what a emulsion tube is?
Post by hopper350 on Jun 27, 2013 21:25:36 GMT 1
emultion tube is what your main jet screws into, you see this when you take the float bowl off the bottom of the carb and your needle slides up and down in it wich meters fuel and is attached to the throttle slide when you pull the throttle twist grip if you can understand me. sorry aint got a picture of the air screw location.
Post by The Pirate on Jun 28, 2013 16:31:05 GMT 1
emultion tube is what your main jet screws into, you see this when you take the float bowl off the bottom of the carb and your needle slides up and down in it wich meters fuel and is attached to the throttle slide when you pull the throttle twist grip if you can understand me. sorry aint got a picture of the air screw location. ah a see,, yea a know which part you mean now,thanks for the reply,, can these ever be the wrong size or are they just a standard size? and still want to know what an air jet is and where its located???
Post by oldelsieboy on Jun 28, 2013 16:46:30 GMT 1
can anyone tell me or show me a picture of where the air jet is on a 1ua carbs,,, im checking all things in the carbs which seem to be wrong for my f2,, and now its the turn to check the air jet but I have no idea what im looking for ............ oh and before a forget a also need to know what a emulsion tube is? THIS MAY BE OF SOME HELPOEB
Post by The Pirate on Jun 28, 2013 17:27:43 GMT 1
looks good but I can only get the first page to load,,,, anyone send me this via email,,, andypied@aol.com would be greatful,, thanks
Post by oldelsieboy on Jun 28, 2013 17:30:43 GMT 1
looks good but I can only get the first page to load,,,, anyone send me this via email,,, andypied@aol.com would be greatful,, thanks email sent OEB
Post by The Pirate on Jun 28, 2013 17:40:26 GMT 1
received with many thanks,,, that should make good reading,, thanks again
