Post by dingbat on Jun 27, 2013 16:44:16 GMT 1
Can one tell me what the output should be on the 500 LC, as i need to know to see if the CDI is getting enough power.Also anyone know where to get the rotor re-magnetized.
Cheers
Dingbat
Post by bryan on Jun 27, 2013 17:54:13 GMT 1
e manual here for you www.rzv500r.net/rd500lc47x.htmlif you have a good broard band connection i will email you 3 folders I have with all the pages copied to on my hard drive.
Post by dingbat on Jun 27, 2013 22:27:07 GMT 1
Hi Bryan thanks for that. michael@msmith723.wanadoo.co.uk
Post by bryan on Jun 27, 2013 23:21:57 GMT 1
sent the first file with 100 pages. You should be getting about 14v at the battery at 2000rpm. whays the problem with the bike as it could be the reg/rec.
Post by dingbat on Jun 27, 2013 23:37:14 GMT 1
Have no spark at all, pickup is pulsing ok,changed the CDI sCoils test ok still nothing, thats why i need to know the output of the generator, which could only leave the rotor.
Thanks for your help Bryan.
Post by cb250g5 on Jun 27, 2013 23:38:14 GMT 1
Never been lucky enough to own a 500 (yet), but do they have battery powered CDIs, or self generating, like the 250s & 350s ??
Post by Norbo on Jun 28, 2013 6:03:30 GMT 1
self generating mate same as lc's and valves I think.
Post by cb250g5 on Jun 28, 2013 7:30:58 GMT 1
So at kickover speeds there's a bit of AC coming from the mag coils, hard to measure, but obviously enough to get the CDI to work.
Post by Norbo on Jun 28, 2013 7:41:01 GMT 1
yes you should be able to start a bike without a battery the stator gives enough charge to give a spark on tick over
Post by bryan on Jun 28, 2013 8:47:24 GMT 1
if you look on the sheets i sent you, you should find 2 values for the stator ohms readings. There are 3 wires that make up the high speed windings and low speed windings, there is a common wire which is used for both readings.
Post by bryan on Jun 28, 2013 8:55:59 GMT 1
Post by dingbat on Jun 28, 2013 10:43:28 GMT 1
Post by LC_BOTT on Jun 28, 2013 18:54:45 GMT 1
Have you tried another CDI? would think it's more usual for a CI to go pop rather than the generator ( I know you're unable to check that though.) Aren't most generators 2-300V plus??
Post by dingbat on Jun 28, 2013 19:30:40 GMT 1
:)Thanks for all your help and input guys, I have been on another site RZ/RD 500 for about 6 years with only one comment with my present problem. On here loads of help and tips, I feel like part of the family already.
The good news is, even though the pick up was pulsing, and changed cdi, I changed for another pick up and now we have sparks yeahhhhhh
Thanks again Bryan.
It was a good excuse to buy a zeeltronic cdi/pv controller and hand held programmer from Norbo. will be much better on track days.
Post by bryan on Jun 28, 2013 19:54:14 GMT 1
did the problem show up on the ohms reading for the pulsar coil?
Post by dingbat on Jun 28, 2013 20:07:30 GMT 1
No Bryan, all the tests were ok, as I said it was pulsing but not enough.
Post by bryan on Jun 29, 2013 4:34:37 GMT 1
had the same thing on my LC when I fitted Zeel and lenthened the slots on the statoe, soon as revs hit about 5,500 engine would cut out and not restart. Tested the pulsar coil a few times and it read ok, happened to get no reading next time I checked it.
