Post by johnlc on Jun 27, 2013 14:56:36 GMT 1
My 4l0 is burning more 2 stroke on the rhs when I give it a handful it gives a puff then clears ok usually after pootling around town could it be something to do with check valves in pump .blue smoke not white
Post by arrow on Jun 27, 2013 15:00:40 GMT 1
Yep, sounds like a check valve is passing. Also, synchronisation of the carbs plays a part, the lazy pot will smoke more due to the combustion temperature being a bit lower.
Post by Yogi on Jul 3, 2013 21:02:47 GMT 1
My 250ypvs was like that after a rebuild,,,,turnt out it was the carbs,,,also one exhaust was hotter,,runs sweet now
Post by johnlc on Jul 3, 2013 22:05:49 GMT 1
Thats what i am starting to think its running a bit rough low down but is fine in the band .Pwks by the way possibly choke is sticking
Post by billy on Jul 4, 2013 4:48:24 GMT 1
I always thought it was the opposite, left wingers smoke more pot that right wingers!?
Post by johnlc on Jul 7, 2013 22:28:24 GMT 1
Boiled carbs in lemon juice gets the outside quite clean as well .balance was way off left side moving a lot before the right even thinks about it .Hopefully this sorts the smoking also cleaned the check valves in the pump
Post by steve h on Jul 7, 2013 23:14:36 GMT 1
I always thought it was the opposite, left wingers smoke more pot that right wingers!? Billy, this whole country has gone to pot.
Post by johnlc on Jul 7, 2013 23:34:09 GMT 1
Never worked still have low down misfire but is dependant on throttle opening still have a wee puff of smoke on rhs too
Post by arrow on Jul 7, 2013 23:54:00 GMT 1
Did you check the operation of the check valves in the oil pump after you cleaned them?
Post by johnlc on Jul 8, 2013 0:29:42 GMT 1
No I never thought about that .How do I do it
Post by johnlc on Jul 8, 2013 17:19:43 GMT 1
Swapped oil feeds over made no difference plus bike has a low down misfire but fine in the band .carbs are pwk's
Post by arrow on Jul 8, 2013 19:49:29 GMT 1
No I never thought about that .How do I do it Pump has to be stripped for that check. I check them with air. If you swapped the feeds over it may take a while to show up. Build up in exhaust etc. Even if a valve is passing completely the flow wont be much at all.
Post by johnlc on Jul 8, 2013 21:19:48 GMT 1
Rhs exhaust is cooler than lhs after idling for a while
Post by johnlc on Jul 9, 2013 20:46:04 GMT 1
Could the reed valves be anything to do with the poor running
Post by loctite on Jul 9, 2013 21:29:17 GMT 1
re torque cylinder head to start with, check oil pump, this was similar symptoms has mine ie poor running lucky I had spare crank and barrels,now fitted and running well,,,,,ish
Post by johnlc on Jul 10, 2013 11:39:59 GMT 1
Took the head off this morning and the lhs is cleaner than the rhs , checked the reeds and pistons and all seems ok thinking it was the lhs that was misfiring as it was a lot hotter than rhs , fitted new top end gasket set and gave it a decoke hopefilly this will fix the poor running
Post by arrow on Jul 10, 2013 13:21:02 GMT 1
I had an issue like this with my 250e four years ago. Eventually cured it by replacing the L/H carb body. Think your issue is deffo due to fueling.
Post by johnlc on Jul 10, 2013 13:44:08 GMT 1
In the head the left side was really clean compared to rhs which had normal coked up look about it thought this may be what the problem was plus left side was a good bit hotter which got me thinking that way , now I think about it , it was using a little water but never gave it a second though as it was such a small amount
Post by johnlc on Jul 12, 2013 19:19:16 GMT 1
Swapped carbs for other pair and misfiring seems to have almost disappeared just a play with pilot settings should see it gone .Other pwk must have a blockage in the passageways
Post by arrow on Jul 12, 2013 19:36:26 GMT 1
Sounds just like the problem I had.
Post by Yogi on Jul 12, 2013 19:38:28 GMT 1
As I thought it was the carbs,,,,glad you sorted it
Post by johnlc on Jul 12, 2013 20:50:21 GMT 1
Now how to clean carbs properly what like are those cheap ultrasonic cleaners
