Post by ashman555 on Jun 26, 2013 7:55:51 GMT 1
Hi after some advise , fitting a 31k motor in 4lo frame it will have a standard rd350lc 4lo rad on it , I'm sure some one told me to blank off the return hose on the head and drill a small hole in the thermostat ? Does this sound correct !!!! Thanks
Post by jessy03 on Jun 26, 2013 9:22:38 GMT 1
the engine will slot straight in, you will need to do the following mods though -
1, drill 2nr 3mm holes in thermostat 2, plug the bypass outlet from the head ( pipe/allen bolt and jubilee clip) 3, Trim the generator side engine case to fir or fit the LC one
then you have all the electrics etc... to do
Jess
Post by ashman555 on Jun 27, 2013 7:30:32 GMT 1
Thanks for the advise mate
