Post by griff on Jun 24, 2013 21:06:46 GMT 1
hi guys I have restored a 350lc and im having probs starting it wen cold and wen I do get it running it will only tick over at 2000k any less and it cuts out iv tried the float bowls and thay are ok I have all so put new crank seals as I was told it could be them but still no change anybody got any idears
Post by marsbar350 on Jun 24, 2013 21:17:28 GMT 1
pilot jet blocked. bowls on wrong carbs welcome griff
paulo
Post by paulo on Jun 24, 2013 21:32:19 GMT 1
Good strip down & cleaning of the carbs would be a good starting point. Make sure all jets are not blocked. Confirm float height settings and ensure correct bowl is fitted to correct carb. Return all settings to standard ie air screw / needle height. Sync carb's and double check oil pump setting. Then cross your fingers and fire it up. Welcome to the forum mate.
Post by griff on Jun 24, 2013 21:56:05 GMT 1
cheers lads carbs have had all new jets in them not sure how to check float levels or pump setting could u add vice
Post by marsbar350 on Jun 24, 2013 22:01:12 GMT 1
cheers lads carbs have had all new jets in them not sure how to check float levels or pump setting could u add vice arrow can sort ya pump out do a search for float height settings its been covered recently.can find the thread
Post by griff on Jun 24, 2013 22:35:57 GMT 1
wats a plug chop
Post by arrow on Jun 25, 2013 6:50:29 GMT 1
Is the little rubber balance pipe fitted in between the two carbs? Welcome in.
