Oil lines
Jun 22, 2013 18:05:24 GMT 1
via mobile
Post by davey on Jun 22, 2013 18:05:24 GMT 1
Well i tryed and tryed to get the spring clips on that were supplied with the oil lines from yambits and im fooked if i can get em on. I oiled em , greased em and only acheved butchering the end of the tube . Any other tips guys would be great
Thanks
Post by Taylormade on Jun 22, 2013 21:00:00 GMT 1
I'm not sure what's going wrong? I ordered the oil lines and clips from the Yambits kit and I had no issue? Don't get me wrong the pipes were bloody tight to get on but the clips were easy? Unless we're talking about different clips??? I've heard genuine Yam are a bitch to fit.... Hope you get it sorted mate
Oil lines
Jun 22, 2013 21:39:01 GMT 1
via mobile
Post by davey on Jun 22, 2013 21:39:01 GMT 1
These are the clear lines if it helps
Post by arrow on Jun 22, 2013 21:52:50 GMT 1
Oil lines
Jun 22, 2013 22:10:30 GMT 1
via mobile
Post by Delbert on Jun 22, 2013 22:10:30 GMT 1
Well i tryed and tryed to get the spring clips on that were supplied with the oil lines from yambits and im fooked if i can get em on. I oiled em , greased em and only acheved butchering the end of the tube . Any other tips guys would be great Thanks I had the same problem mate and gave up as started to damage the tube, as arrow says I think the genuine pipe is smaller outer diameter . The question should be , why do they sell it if it don't fit , unless they are unaware of the problem , think I will send them a mail
Post by Delbert on Jun 22, 2013 22:12:52 GMT 1
Post by Taylormade on Jun 22, 2013 22:24:34 GMT 1
The link arrow has put up are the ones I used with the clear pipe from Yambits and no issues.
Post by nikfubar on Jun 22, 2013 22:25:57 GMT 1
Oil lines
Jun 22, 2013 22:52:13 GMT 1
via mobile
Post by Delbert on Jun 22, 2013 22:52:13 GMT 1
The link arrow has put up are the ones I used with the clear pipe from Yambits and no issues. I have just emailed them to see what they have to say ,, probably nothing ,, maybe a few duff sets with the wrong clips ?? Point is if you buy a kit you shouldn't have to buy other clips from them because the first lot don't fit
paulo
Post by paulo on Jun 22, 2013 23:06:52 GMT 1
Had a few sets now from them and never had any problems with either pipes or clips. Only problem is getting them off again, normally have to slit the pipe at the carb oil inlet to remove - at least you know they haven't been drawing in air !.
Post by arrow on Jun 23, 2013 0:48:17 GMT 1
Guy's, when you fit the standard Yamaha retainers you should push the "top layer" of the collet round so that it reduces the grip on the pipe, and push the same into position at the same time. If anyone needs the part number for the correct spec. gen. pipes, just ask, they are not overly expensive.
Post by nige on Jun 23, 2013 7:39:37 GMT 1
The prob I had with the yambits oil lines was how quick they go hard. Got them on ok but will be another thing getting them off where they hard (and discoloured).
Oil lines
Jun 23, 2013 8:26:57 GMT 1
via mobile
Post by davey on Jun 23, 2013 8:26:57 GMT 1
Thanks guys , gary the ones you showed me are the ones i have. I tried again and im gonna spit the dummy if i continue. Just will throw in the towel and get some gen ones like i should of done . Tha real reason was the fact they were clear which is y i got them . But at least its not just me thats had problem
Oil lines
Jun 25, 2013 20:40:35 GMT 1
via mobile
Post by Delbert on Jun 25, 2013 20:40:35 GMT 1
Well i tryed and tryed to get the spring clips on that were supplied with the oil lines from yambits and im fooked if i can get em on. I oiled em , greased em and only acheved butchering the end of the tube . Any other tips guys would be great Thanks Davey I emailed yambits & have had a positive response ,, caroline told me they had a small batch of pipe that was the wrong outer diameter and has since been withdrawn from sale and that they have gone back to the original supplier , she went on to say that having found my original order a new set of oil lines will be sent with clips that will fit !! Result! Worth a polite email mate
Post by copper99 on Jun 25, 2013 21:09:30 GMT 1
Good result Delbert.
On a similar subject, im after the main line from tank to pump, are they still available from Yam? Thanks
Oil lines
Jun 25, 2013 23:29:11 GMT 1
via mobile
Post by Delbert on Jun 25, 2013 23:29:11 GMT 1
Im sure arrow said the oe spec stuff is still available from yam
Post by arrow on Jun 26, 2013 6:46:21 GMT 1
I ordered the correct spec oil line from Yamaha a few years ago. The stuff that came was more like the coolant expansion pipe, big and heavy gauge. I have found the best original looking oil tank to pump pipe is the fuel pipe from Yambits. Although the Yamaha outlet pipe is spot on.
Post by davey on Jun 26, 2013 12:35:45 GMT 1
Hi Delbert, Thanks for the heads up , what you say would make complete sense. i just mailed them so ill see if i get a reply. thanks again mate
Oil lines
Jun 27, 2013 12:57:35 GMT 1
via mobile
Post by davey on Jun 27, 2013 12:57:35 GMT 1
Just got a reply from caroline at yambits and she is sending me a replacement kit. Great customer back ip i say
Post by steelerd on Jun 27, 2013 14:22:11 GMT 1
so which ones are the dodgy ones then Ive got some to try and get on later haha
Oil lines
Jul 6, 2013 10:34:12 GMT 1
via mobile
Post by Delbert on Jul 6, 2013 10:34:12 GMT 1
Well what a doddle with the correct pipe & clips !! ,, one question I have , is it normal for the oil lines to rest /touch the barrel as it runs behind the pump cable or should there be some sort of clip there ??
Post by arrow on Jul 6, 2013 11:37:45 GMT 1
There should be two guides on two of the casing screws.
Oil lines
Jul 6, 2013 12:00:01 GMT 1
via mobile
Post by Delbert on Jul 6, 2013 12:00:01 GMT 1
Ok thanks arrow , will source some
Post by steelerd on Jul 26, 2013 18:38:49 GMT 1
just to bump this anyone have any idea what the wrong outer diameter was on the bad batch just come to put mine on an f me got the clip onto the line but it wont go over the line at the pump end darn it haha
doesnt seem wide enough to slide over the spigot on the pump
Oil lines
Jul 26, 2013 21:49:15 GMT 1
via mobile
Post by Delbert on Jul 26, 2013 21:49:15 GMT 1
Just had a quick measure up with the sadometer !! The wrong size comes in at 6mm whilst the correct pipe measures 4.5mm .. Hth
Post by steelerd on Jul 26, 2013 23:14:33 GMT 1
yup same as mine darn it thanks for measuring up though mate and i was gonna book the mot to haha gonna be phoning yam bits I think bout the 3rd item ive had greif with so far a kill switch strip that i had to spend ages sanding of then a dial test gauge where the i had to cut the probe down to the right length that took ages and was so close to taking to much off then the oil lines pretty bad hit rate out of ten products reminding me of norton parts lmfao wouldnt mind if they were cheap but 0.o lol lets hope they get it sorted
