Post by baz69 on Jun 22, 2013 0:33:08 GMT 1
hi all ,when preparing frame and s/arm for powdercoating besides removing all rubber grommets etc,do i need to take bushes out of swingarm or can they be left in ,guy said all tgreaded holes etc will be covered .
Post by fatfastroger on Jun 22, 2013 8:49:33 GMT 1
Best to remove the bushes, blasting process and coating process will probably damage them. Plus the powder coating will cover the ends and when you replace the bushes later on the coating will chip away as you try to remove them. (I know this from bitter experience)
Post by baz69 on Jun 22, 2013 10:17:34 GMT 1
ok thanks,whats best way to get em out without damaging them ?
Post by muttsnuts on Jun 22, 2013 10:36:24 GMT 1
hitting them carefully with a big f**k off hammer....... only kidding, you need to use various size drifts etc, or if its bearings, then bearing pullers, each type of bush/bearing will need a different approach, oh and a big f**k off hammer.....
Post by baz69 on Jun 22, 2013 10:48:00 GMT 1
thanks ,guy i bought bike from is asking me not to powdercoat frame as i will lose authenticity as bike is completely std and in v good cond frame itself isnt bad some marks and scuffs few rust spots,what about 2pack spraying instead was goin to shelve frame work but its like stripped and if i dont do something now i never will,
paulo
Post by paulo on Jun 22, 2013 17:05:43 GMT 1
Your bike now, so up to you, but they do look nice painted in two pack !, but power coat is very durable.
Post by copper99 on Jun 22, 2013 18:18:35 GMT 1
If its powdercoated or re-painted, it still loses authenticity, No?
Mines powder coated, given the choice, id go that route again, just because of that durabilty, modern paint just isnt the same as it once was.
Post by rickbrown01 on Jun 22, 2013 18:24:18 GMT 1
One advantage of paint is if it does get a chip you can rub it down and repair it where as powder coating is very hard to repair,but obviously up to you.
Post by winnerevo1 on Jun 23, 2013 10:52:24 GMT 1
Either 2 pack or stove enamel will be much closer to original. I agree with above, powder coat is crap if you want to buff out any scratches etc.
