robw
Post by robw on Jun 18, 2013 20:23:55 GMT 1
Hi, just built the Gamma and have running problems with the engine. It starts fine and runs in the garage fine, although the revs did take time to return to normal. That was sorted by turning the air screw out and changing the pilot valve. It has Kenny's pipes and foam air filters fitted, rest is standard. Main jet - 280 Pilot jet - 25 Needle - 4 from top As you pull away it gradually dies and unless the choke is pulled out it comes to a halt, regardless of throttle position. If you ride it with the choke on it rides normally. I think it still needs a bigger pilot valve, but that is a uneducated guess. I have checked all the drillings in the carbs and have the float valve height (21mm from gasket face) . Any ideas from the more savvy people out there. Cheers Rob
Post by Yogi on Jun 18, 2013 22:33:30 GMT 1
Hi Rob have you got balance pipe on between the carbs? Have you blocked the vacuum hole on inside of right carb.? Are the float bowls on the correct carbs ? Have you blocked the 2t oil pipes on the bottoms,if not used ? Are there any air leaks ?
robw
Post by robw on Jun 19, 2013 7:04:19 GMT 1
Hi, balance pipe on, oil pipes in use. I have put a tube on the vacuum pipe with a screw in the end, held in with a clamp. I will check the float level using the tube that is attached to the float bowl drain. I will let you know how I get on Rob
Post by midlifecrisisrd on Jun 19, 2013 8:28:59 GMT 1
Hi,
I'd say you are too lean. on the pilot and maybe on the main. What carbs you running?
Thought YPVS carbs used a 27.5 pilot as standard. I used 260's with an airbox so you may be better starting at 300.
paulo
Post by paulo on Jun 19, 2013 19:40:20 GMT 1
What carbs and engine are you running - as each type of carb have certain basic setting as a start point.
Post by fatfastroger on Jun 19, 2013 19:46:39 GMT 1
Kenny advised me to use 290 mains with standard airbox (snorkel removed) so I'd say you're running a bit weak,esp with pod filters. I have yet to get mine running but have 31k engine and carbs with Kennys pipes. Pilots are 22.5 standard. If the air screws are roughly 1 to 2 turns out and it starts and idles then surely the pilots are in the ball park ? Pulling the choke will richen the mixture so maybe that confirms either main is too small or you have an air leak.
Post by steeley on Jun 19, 2013 20:58:23 GMT 1
check the emulsifier tube ,the brass tube that the main jet goes into.does it have a raised shield on it or is it flush with the carb.if it has a shield then they a ledar items .if so put the clip in the lowest groove to raise the needle.had a similar problem years ago, bike would not pull off .raised the needle and bike would pick up ok.my tzr 350 ypvs 31k engine kennys pipes ramair foam filters 290 mains colour looks good on the plugs oh and home made boost bottle made out of copper pipe.
robw
Post by robw on Jun 19, 2013 21:01:01 GMT 1
Hi, I have 31k00 carbs fitted, so standard jets are 260 and I went two up to 280. I will go up to 300, It does cough and splutter when I open the throttle so I will play with the main jets as well. Cheers Rob
robw
Post by robw on Jun 19, 2013 21:02:52 GMT 1
It does have the raised shield emulsion tube as well, so I will put a bigger jet in first then play with the needle Rob
Post by andreas67 on Jun 19, 2013 21:14:47 GMT 1
I am running main jets 280 with TSA pipes and pods and the needle is 5th groove from the top. This did enrich it when running part load, this was clearly visible on the exhaust temp (lower).
Post by steeley on Jun 19, 2013 21:28:59 GMT 1
rob, sounds like you are going in the right direction hope you have it sussed soon .
Post by fatfastroger on Jun 19, 2013 21:33:56 GMT 1
let us know how it ends up - no 2 engines will be the same, better to be slightly rich, till you can plug chop at full gas
Post by midlifecrisisrd on Jun 20, 2013 8:12:59 GMT 1
OK I stand corrected, 22.5 pilot is standard ( I said 27.5 ) knew it was something .5 lol.
At risk of getting it wrong again the 31k carbs were 240 mains as standard so you are 4 sizes up.
robw
Post by robw on Jun 21, 2013 18:45:17 GMT 1
Finally a big improvement. I have accurately set the float bowls as they were out, using the blow down a pipe until you feel faint method. I have also put a 330 main in, which I will replace with a 300 to see if it runs well still. Air screw is all the way in, so I will fit a 27.5 to enrich the slow running circuit(that's the correct way?) It hunts at 3000 revs, so hopefully this points to its still running lean Rob
Post by fatfastroger on Jun 22, 2013 8:45:38 GMT 1
glad that you're getting a result, 330 main ! Must be a big hole !
robw
Post by robw on Jun 22, 2013 9:57:04 GMT 1
After the previous adjustments, as I blipped the throttle, the revs would become uncontrollable. So after a good check, I could see no leaks and have returned to a 25 pilot jet and 300 main, so I will see what this is like. If all else fails I will go back to the previous adjustments where everything ran well.
robw
Post by robw on Jun 22, 2013 10:16:48 GMT 1
That's what I thought, slides work well as I checked them before and after. As for the leak it has new carb rubbers which are tightened, I have checked the vacuum pipe and ensured that its still sealed. So running out of ideas Rob
robw
Post by robw on Jun 22, 2013 11:01:06 GMT 1
Found the rev problem, right hand slide sticking only when engine is running. Any suggestions on cause and rectification Rob
robw
Post by robw on Jun 22, 2013 20:05:55 GMT 1
Finally sorted, I put a better spring underneath the cap on the right hand carb, and this has solved the sticky slide. Taking time to ensure that the carbs are synchronised paid dividends as well. To sum up 300 main jets 25 pilot jets Air screws 1 thread out Needle jet- 5 groove from top
No doubt it will need tweaking as it runs in Cheers everyone for your help Rob
Post by steeley on Jun 23, 2013 6:01:55 GMT 1
nice to hear you have got it sorted rob.
Post by 1966baz on Jun 23, 2013 19:27:07 GMT 1
Well done mate - good result.Usually takes abit of patience but you've got there. Cheers Nick.
