Post by The Pirate on Jun 16, 2013 20:05:26 GMT 1
ive spent the whole day trying to sort the wiring on the ypvs f2 that im re-building, getting it all re-routed where its meant to go,,, on this ocasion my memory did not serve me well and a forgot the path that everything took "dur" anyhow everything is just about sorted apart from the only bit that has me stuck "the HT coil" and its got me stuck on two simple matters,, firstly picture yourself sitting on the bike with no tank on,,, looking down you can see the coil with the two HT leads pointing towards you,,, does the left lead go to the left plug and the right to the right plug,, or do they go to the opposite way? and second question is the lower tension wires,,, which colours go to the left and right? ?? I know there is a thread on this as I have read it before,, ive had a quick look but cant seem to find it, and im hoping to finnish the job tonight so I can move onto something else,,,,,,,,,,,,,,,,,, cheers guys
Post by The Pirate on Jun 17, 2013 18:01:35 GMT 1
any help on this please
Post by The Pirate on Jun 18, 2013 21:10:00 GMT 1
BUMP,,,,, still stuck and in need of help with this please
paulo
Post by paulo on Jun 19, 2013 19:51:15 GMT 1
Hi pirate, not got a F2, but I would think the Lhs coil lead would go to the Lhs cylinder and the Rhs to the Rhs cylinder - it does on the LC !. As for wiring, orange lead is to the positive side and black to the earth side - sorry can't help more than that !.
Post by fatfastroger on Jun 19, 2013 19:52:47 GMT 1
left lead to left plug, but both leads fire at the same time as system is a "wasted spark" ie fires at tdc and bdc as for the low tension side it must have a plug that can only go in one way, maybe a picture here from you might help
Roger
Post by The Pirate on Jun 19, 2013 20:10:47 GMT 1
left lead to left plug, but both leads fire at the same time as system is a "wasted spark" ie fires at tdc and bdc as for the low tension side it must have a plug that can only go in one way, maybe a picture here from you might help Roger its not a plug, it two 45 degree turn spade conectors,, one oronge wire and one black wire that goes to the opporsit side of the coil to the ht leads,,,, will see if I can sort a picture out,, but many thanks so far
Post by nige on Jun 19, 2013 20:17:46 GMT 1
Black is the ground orange is the live but don't think the coil is polarity conscious. On my f2 orange was longer slightly so put on furthest spade before I fitted banshee coils ( which are far better than original coil). Ht leads don't matter which way round either.
Post by The Pirate on Jun 19, 2013 21:22:21 GMT 1
here is the pictures guys,,, oh and both wires are the same length,, and ive no idea why there is a bit of white tape on the black wire,,,
Post by fatfastroger on Jun 19, 2013 21:30:11 GMT 1
Have you got a multimeter to measure ohms ? If so check each terminal to earth (frame) zero ohms indicates the terminal is grounded and should be the black wire. if both contacts are not at zero then it prob does not matter which is which. Either way if you get it wrong its unlikely to damage anything, you'll either have a spark or not
m1ke
Post by m1ke on Jun 19, 2013 22:09:54 GMT 1
Doesn't matter which way round they go on...
Post by The Pirate on Jun 20, 2013 17:03:33 GMT 1
thanks guys,, as always a big help
