Post by Dieseldog on Jun 13, 2013 22:10:58 GMT 1
Hi, Anyone know were to get clear brake fluid line from (reservoir to master cyl). Got some of that HRC stuff from fleabay but appears to be 'sweating' - fluid is passing through (porous?) the hose. Looks like condensation on the outside of the hose after a couple of days but it is actually brake fluid
Post by midlifecrisisrd on Jun 14, 2013 8:37:46 GMT 1
Yes fell for that ebay crap too which has ruined the paint on my master grrr
Interesting to see what others have used.
Post by Dieseldog on Jun 14, 2013 9:46:09 GMT 1
Post by winnerevo1 on Jun 14, 2013 11:23:10 GMT 1
To be honest I've read lots of posts with the same issue which dissuaded me from using such a thing on my bike.
As Headcoats states, I too would say they are unsuitable for a road bike. The problem you discribe is probably not an issue on a race bike that continually gets it's brake parts changed.
Post by Dieseldog on Jun 14, 2013 11:28:29 GMT 1
To be honest I've read lots of posts with the same issue which dissuaded me from using such a thing on my bike. As Headcoats states, I too would say they are unsuitable for a road bike. The problem you discribe is probably not an issue on a race bike that continually gets it's brake parts changed. Probably not even suitable for race bike as it only takes about a week for it to happen
Post by winnerevo1 on Jun 14, 2013 13:18:07 GMT 1
HRC kit race bikes probably get that part binned after every meeting/race. That is of course if the one you bought is genuine HRC.
Post by Dieseldog on Jun 14, 2013 17:21:01 GMT 1
That is of course if the one you bought is genuine HRC. You mean people sell counterfeit parts on fleebay
paulo
Post by paulo on Jun 14, 2013 17:28:01 GMT 1
Got one from NK racing for the rear. Little bit of moisture when I first fitted it, I reduced the level approx 10mm from the tube cap and it's been ok ever since. Don't know about being parked up in direct sunlight ?, always tucked under a cover in the garage.
Post by midlifecrisisrd on Jun 14, 2013 17:38:34 GMT 1
Unfortunately I have little choice as my airbox has been moved back slightly so standard one does not fit.
Do have a new Yam hose so may have to use a miniature res on it.
Post by Dieseldog on Jun 14, 2013 20:11:56 GMT 1
Got a reply from Doble m/cycles
"I have used these on my track bike and experienced the same sweating type effect. I wiped it a couple of times and it never returned.
Give it a go."
Must be genuine HRC quality stuff. Cannot see how wiping off will stop it from happening. So looks like the hose is going to get filed under 'Bin' Second thought - maybe if I use golden syrup as brake fluid it might be to viscous to seep through.
hrc43
Post by hrc43 on Jun 15, 2013 9:13:41 GMT 1
i've had a couple of rs 250 honda race bikes and the brake lines used to sweat on them but it was only condesation not fluid bleeding thro the lines .if its fluid coming thro it wont be hrc their stuff is the best you can buy
Post by nikfubar on Jun 15, 2013 9:52:29 GMT 1
On my last build I tried several different types of clear hose & they all "sweated" or dissolved so I went to a specialist manufacturer of hydraulic hoses & lines, they told me there was only one type of clear line that is up to the task but it is semi rigid so it comes with a stainless steel brading sheith to stop it kinking, if it's a straight run it could be used as a clear hose, I still have a 300mm long piece spare if you want it, BTW it has an 8mm internal bore. It is thin walled & feels more like plastic than rubber.
Post by Dieseldog on Jun 18, 2013 14:49:44 GMT 1
I still have a 300mm long piece spare if you want it, BTW it has an 8mm internal bore. It is thin walled & feels more like plastic than rubber. Cheers for that but its not a straight run, loops round through 180
