Post by motorcyclegirl on Jun 13, 2013 21:04:56 GMT 1
I picked up what I thought was the centre stand for my RD350LC but it does not seem to fit right. Is there a trick to putting it on? or How can I tell if it is the right one?
thanks
Celeste
Post by winnerevo1 on Jun 13, 2013 21:54:22 GMT 1
Can you post up a pic of it? They are straight forward to fit but attaching the hook & spring is awkward and takes a bit of practice. This is what it should look like.......
Post by motorcyclegirl on Jun 13, 2013 23:30:30 GMT 1
Well I solved my own problem...yes I have the right stand, spring and c hook...the issue is that my frame is missing the two outside tabs. So the stand rubs against the tire....
I guess I will be putting the stand up for sale. ;-) Celeste
Post by steeley on Jun 14, 2013 13:27:04 GMT 1
ah brackets cut off to fit a set of after market pipes.not long made and welded a pair on my lc 350 ,well I did cut them off about 17 years ago to fit a pair of s/s pipes.
Post by motorcyclegirl on Jun 14, 2013 13:41:35 GMT 1
Oh well I was trying to get it as stock as possible. Not going to take it all apart to weld on a couple of brackets. Perhaps if I need to rebuild it another time I will add the centre stand back on
