robw
Post by robw on Jun 8, 2013 12:37:31 GMT 1
Hi, the cable on my Yammagamma is at its max adjustment and just works, anyone know of a shorter cable(1/2" shorter) Rob
Post by winnerevo1 on Jun 8, 2013 13:03:49 GMT 1
Depends what clutch cable you already have fitted... I've used an FZR600 Genesis on my LC/YPVS Hybrid because it was shorter than an LC/LC2 cable.
robw
Post by robw on Jun 8, 2013 13:25:51 GMT 1
Thanks, do you know how much shorter Cheers Rob
Post by Yogi on Jun 8, 2013 14:15:53 GMT 1
I had an engine rebuild and all set up right with a new cable from Norbo and it was still to long,so I put an extra adjuster on where it bolts on case,it works perfect now
robw
Post by robw on Jun 8, 2013 14:57:18 GMT 1
That's a good idea, I will try out Cheers Rob
Post by winnerevo1 on Jun 8, 2013 15:29:26 GMT 1
Thanks, do you know how much shorter Cheers Rob I would say of the top of my head it was ½" - 1" shorter, can't really be more exact than that but it was perfect length for mine. The LC2 cable would run out of adjustment and not get full swing of the clutch arm. A little tip that I did, look on the Wemoto site at clutch cables for each model, on the info icon next to the cable it gives the sizes.
