Post by phil916 on Jun 8, 2013 11:47:44 GMT 1
Hey all! Just finished my 350LC / RGV hybrid build and have a problem with the exhausts? I bought a set of large can Allspeeds of eBay ( without seeing them first....never again! When someone says 'good useable condition' , chunks of metal filler on the sides to try and fill holes and a broken baffle spring is not how I'd describe them!! ) Anyway.... With the RGV RJ22 banana swing arm the left hand pipe doesn't fit, it hits the side of the swing arm! The right went on no problem but not the left. Seeing as they are knackered anyway I decided to 'dent' the inside of the can so as to miss the arm. This worked well, but is not right! See pic. My question therefor is what exhausts can I buy that will fit without adjustment?? I need a new set anyway cause of the holes in these but don't want to go through the same malarkey with a different set! Do I need someone to make a purpose built set? Thanks in advance! P.s. if anyone is selling a set that they know will go straight on please let me know! Attachment Deleted
Post by midlifecrisisrd on Jun 8, 2013 17:27:34 GMT 1
small cans should have more clearance due to the smaller diameter. had a set on my ypvs/vj22 and they fitted fine.
either get a set made to fit the bike or the other way is to get 10 mm spacers to move th footplates wider which will give 10 mm mote clearance.
steve
robw
Post by robw on Jun 8, 2013 20:47:29 GMT 1
Take your bike over to TSA and Kenny will fit a set to the bike. He did the same for my Yamagamma Rob
Post by jessy03 on Jun 9, 2013 9:33:06 GMT 1
I fitted a 10-15mm spacer behind the foot rest hanger, I can send you a pic if you need one, pm me your email addy. Jess
Post by loctite on Jun 9, 2013 10:38:46 GMT 1
I fitted a 10-15mm spacer behind the foot rest hanger, I can send you a pic if you need one, pm me your email addy. Jess +1
Post by phil916 on Jun 10, 2013 22:58:32 GMT 1
Cheers for the help guys!!
