Post by shandyboy on Jun 4, 2013 21:03:06 GMT 1
Hi Is anyone using large can allspeeds, the reason I ask is whats the best way to seal them on the exhaust ports? They have two springs on each down pipe do you use a special silicone sealant or just a gasket? also do the washers that go on the studs for the springs go before the flange or after the flange ? Any advice would be great thanks Alan
Post by Haggler on Jun 5, 2013 7:07:34 GMT 1
Just use standard gasket on header and 2 x springs, not leaking yet but I have heard of using a special silicone. Wouldn't mind knowing what it is
Post by speedysquires on Jun 5, 2013 7:23:48 GMT 1
I have just used the standard gaskets and had no problems
Post by shandyboy on Jun 5, 2013 9:16:37 GMT 1
Are you using copper or ali ali gaskets ?? Iam picking up some hi temp loctite silicone today will see what its like!! Alaso where have you loctaed your washers for the springs behind the flange or infront?? cheers alan
Post by Haggler on Jun 5, 2013 15:40:36 GMT 1
Using the thick springy type gaskets (Soz for description but are not copper or ally must be about 5-6 mm thick) and put spring washers on after clamps fitted
Post by speedysquires on Jun 5, 2013 19:55:44 GMT 1
Using the thick springy type gaskets (Soz for description but are not copper or ally must be about 5-6 mm thick) and put spring washers on after clamps fitted I'll second that
Post by shandyboy on Jun 8, 2013 23:58:54 GMT 1
Used the gaskets as you have said however they seal ok at the head except that they leek where the down pipe is held on by the springs !! will try paste on it tommorow
Post by Haggler on Jun 9, 2013 7:44:21 GMT 1
Post by picnick on Jun 9, 2013 11:16:49 GMT 1
The flanges on my allspeeds are welded on (no springs) I just use the normal gaskets and sealer
Post by shandyboy on Jun 9, 2013 21:23:06 GMT 1
Fink it might be sorted left the flanges on coz they sealed up mint, put some Loctite silicone sealer down the gaps in the front pipe put the springs back and ran it for 5 mins today all seems ok !! will test it 2morow ha ho next job fit new banshee coils thanks Alan
