Post by nige on Jun 3, 2013 19:45:44 GMT 1
Took the mrs out on the f2 the weekend. Not had clutch slip before. On one occasion whilst banding the clutch slipped at about 6500 . Only happened the once and not happened again. Is this a sign the clutch is on its way out or is it just a case that they don't like they extra strain ? Plates didn't look to bad when rebuilt the engine few miles ago. Is it worth getting uprated clutch springs ? Was told to fit 3 tz springs ? No more as clutch to heavy ? Thx
Post by Yogi on Jun 3, 2013 20:08:44 GMT 1
Is it adjusted right,ie not to tight
Post by nige on Jun 3, 2013 20:23:27 GMT 1
Yes got bit of play in lever and internal grub screw set as per manual . Was thinking of removing side casing and drilling hole in casing at clutch adjustment point. Is this some ting normally done ?
Post by Yogi on Jun 3, 2013 20:46:26 GMT 1
Won't the oil run out?,have you got correct oil in it?
Post by nige on Jun 3, 2013 22:10:57 GMT 1
Yes right oil in it I meant behind round plastic cover drill the hole . Or is the later valvie meant to have a hole in inner casing. Round 3 hole casing has rubber sealing ring round it not sure why as no oil behind it ? Not sure if clutch casing is right casing or casing off earlier model as would seem sense to be able to remove small cover for clutch adjustment.
Post by Norbo on Jun 4, 2013 6:56:02 GMT 1
TZ springs dont make it to heavy on valve they do a bit on an LC but not so a valve . i put them in everything LC and Valve its a must with any build .
Post by nige on Jun 4, 2013 18:02:53 GMT 1
Ok thx do you do them norbo ?
Post by Norbo on Jun 5, 2013 7:29:20 GMT 1
yes i do £15 a set of 3
Post by nige on Jun 5, 2013 21:22:58 GMT 1
Took bike out tonight solo hit the band a few times ;-). No slip just pulled through . Just a one off glitch ?
