Post by shandyboy on May 28, 2013 18:37:38 GMT 1
Trying to see what carbs my bike has on it ? the bike is a 1981 350lc the only numbers on the carbs are T132 ?? any ideas cheers Alan
Post by oldelsieboy on May 28, 2013 18:43:10 GMT 1
Trying to see what carbs my bike has on it ? the bike is a 1981 350lc the only numbers on the carbs are T132 ?? any ideas cheers Alan The carbs should be stamped 4L0-00 or 4L0-01 as the attached photo OEB
Post by shandyboy on May 28, 2013 19:48:16 GMT 1
mine only has T132 on carb as photo
Post by shandyboy on May 28, 2013 22:40:38 GMT 1
Anyone know ? numbers stamped on the other side
Post by muttsnuts on May 29, 2013 8:53:39 GMT 1
can't see in the photo as its all blurry, have you got a better picture ?
Post by shandyboy on May 29, 2013 9:06:52 GMT 1
fupdate found number ID number on carbs says 4L0 01 next problem is how do I tell if they have had factory mods done ?? running 190 mains not sure what pilots are cheers Alan
Post by winnerevo1 on May 29, 2013 13:42:39 GMT 1
The fact that the carbs are stamped 4L0-01 means they are the updated version.
The 4L0-01 carbs should have a 220 main jet, this was one of the updates.
Post by shandyboy on May 29, 2013 16:32:45 GMT 1
Sound will see if I can locate sum 220 jets sould the float bowls be the same on both carbs?
Post by midlifecrisisrd on May 29, 2013 17:20:56 GMT 1
Sound will see if I can locate sum 220 jets sould the float bowls be the same on both carbs? No, choke side has a jet in the bowl, other side is blanked Steve
Post by badger1 on May 29, 2013 19:09:14 GMT 1
I have a 350 4l0 with early barrels and late 01 carbs, when fitted with 220 mains 22.5 pilots it run like a pile of poo. now fitted with 190 mains 25 pilots runs spot on. 2 strokes are not just plug and play they are all Different..
Post by shandyboy on May 29, 2013 19:43:24 GMT 1
Have just cleaned the carbs set float heights still got the 190 in with 22.5 pilots will try it tommorow. both float bowls look identical could not see a jet now Iam confused and iam running large can allspeeds standard air box
Post by oldelsieboy on May 29, 2013 20:01:20 GMT 1
Have just cleaned the carbs set float heights still got the 190 in with 22.5 pilots will try it tommorow. both float bowls look identical could not see a jet now Iam confused and iam running large can allspeeds standard air box The carb with choke should be fitted with a bowl like this, notice the hole/jet in the base (highlighted with red circle) The non choke carbs bowl is similar but the hole/jet is blocked. HTH OEB
Post by shandyboy on May 30, 2013 0:26:08 GMT 1
The choke side is the same as that however the other one is the same as choke the hole is not blocked off. Will this effect anything ?? should I block it off?? cheers Alan
Post by shandyboy on May 31, 2013 17:25:28 GMT 1
Just set my float heights,.set oil pump new plugs carbs balanced fresh petrol in the awld girl and still running crap the bike splutters from 2000rmp till 5000ish rmp like when you first sart it up and its cold, even when warm, then at 5000ish it kicks in wheel in air below 5000ish is crap spluttery as hell feel like a plugs off but there ok!! any ideas 22.5 pilots 190 mains allspeeds, standard air box on stripping carbs seems like I have the same float bowl on both sides (they both have a jet in) will this cause the problem? and should both my slides have cut outs in ? as only the choke one has a cut out Any help would be good thanks Alan
Post by muttsnuts on May 31, 2013 17:34:37 GMT 1
sounds like your air correction jets are blocked, per chance have you vapour blasted them ?
Post by shandyboy on May 31, 2013 18:04:58 GMT 1
No never blasted them.I will be blasting them once I get the bike running right if that ever happens pissed off with it mate
Post by midlifecrisisrd on May 31, 2013 18:27:20 GMT 1
Non choke side with a choke side bowl fitted should be fine as it has nowhere to go.
Would think both slides should be the same which may be your problem
Post by shandyboy on May 31, 2013 18:29:35 GMT 1
Got me head done in slides are defo different one has 2 cuts out in it the other has none, anyone know if this is the problem Forgot to add bike starts mint ticks over great and seems to rev good on paddock stand with no load on the engine thanks Alan
Post by muttsnuts on May 31, 2013 21:41:52 GMT 1
if you get really stuck, send me your carbs and I'll check them over and set them up etc, including ultrasonic clean them for you, I've done a few sets for some people on here, not had any complaints yet.......probably just "hexed" myself with that comment !!
I remove the brass balls and clean the air correction circuit out and put new brass balls in, its generally that which causes various faults like what you have described, its very hard to clean that circuit and jet without taking the brass balls out as there is no direct access to the jet from any other way
HTH
Post by classicjap on Jun 1, 2013 10:42:04 GMT 1
Sometimes its just worn internal components that cause the problems. I have put carb kits in two different RDs lately and what an unbelievable difference it made. Cost about £25 per kit / carb but money well spent.
Crap running on both bikes before the kits went in - they both run great now.
Then balance them up up using the lolly stick method.
Post by shandyboy on Jun 1, 2013 16:50:57 GMT 1
Will order some carb repair kits whats the best ones ?? Also I seem to remember back in the 80s bike seemed to do this when they had been ported!! (splutter low down then take off higher up the rev range) anyone had carbs set up for ported barrels ? engine had a full rebuild when I got it so dont really want to strip it down to check if I can help it.
cheers Alan
Post by classicjap on Jun 1, 2013 20:23:04 GMT 1
I got the kits I used from Yambits - worked a treat for me
Post by classicjap on Jun 1, 2013 20:27:13 GMT 1
When you strip them to fit the new bits, remove the emulsion tube and give the tube and the carb body a good clean. And don't forget to set the float heights after you put the new float valves in
Post by shandyboy on Jun 1, 2013 21:15:47 GMT 1
Stripped and used compressed air down every jet here are some photos of the slides and float bowls as mention earlier on thanks Alan
Post by Delbert on Jun 1, 2013 22:48:02 GMT 1
slides are correct ,, the one with cut out goes in left carb choke side ,, were they fitted correct as in taper on the bottom facing airbox ?
Post by shandyboy on Jun 1, 2013 22:54:31 GMT 1
Yes as they all lined up ok mate
Post by shandyboy on Jun 2, 2013 20:04:27 GMT 1
Up date just put the carbs back on thought what the hell will vapour blast them so a full strip down and in the machine then blow out with compressor fitted them back on expecting the worst however fired straight up and to my suprise spluttering has gone at low revs the bike rides much better it still hesitates from 4k to 5k but still usable so i think its just a case of fine tuning and a couple of plug chops happy days
