justyr
Post by justyr on May 27, 2013 19:56:59 GMT 1
Project RD250C took a hot today when the "RD250" forks I got from evilbay turned out to be 32.5mm dia, not 34.
Can anyone shed some light on this? These forks also do not have the castellated top bung (more like an lc setup), and the caliper mounting holes are spaced wider apart.
Thanks for any advice, before I go back to the seller!
Ta J
Post by Norbo on May 28, 2013 8:44:43 GMT 1
they will be of the Cor D model and you have the E or F model
justyr
Post by justyr on May 28, 2013 9:08:46 GMT 1
Hi Norbo, OK the bike is a C. I measured the original forks on the bike at 34mm. This is correct for the C. Later they changed them to 35mm on the E/F. So what are these 32.5mm ones I've been sent.... hmmm. J
Post by Norbo on May 28, 2013 10:30:25 GMT 1
well if they are A/C they can only be from the Aor B now cant they but 32.5 is a strange size do you have a pic of them,
justyr
Post by justyr on May 31, 2013 13:25:39 GMT 1
pics will come in 3 postings - here's #1 Attachments:
justyr
Post by justyr on May 31, 2013 13:26:06 GMT 1
#2 Attachments:
justyr
Post by justyr on May 31, 2013 13:27:12 GMT 1
and #3. Please could someone tell me what RD250 model these are from? many thanks, J Attachments:
Post by steve h on May 31, 2013 19:22:06 GMT 1
They are not LC, RD400C or RD250E, just checked mine. The mounts for the caliper look similar to those on my 250E. I haven't seen a bridge across the mudguard studs before. Could it be that these are off an XS model??? One with 32mm forks and a single disc? Might be best to see if there is an XS forum and see if someone can help there. Sorry I can't be much help. PS have you checked the aircooled forum?
Post by steve h on May 31, 2013 19:36:04 GMT 1
If they are 33mm (which is what I think) they might be XS 360 or 400 or 250. Just found a diameter chart, but it does not list everything.
Post by marsbar350 on May 31, 2013 19:42:48 GMT 1
If they are 33mm (which is what I think) they might be XS 360 or 400 or 250. Just found a diameter chart, but it does not list everything. look like stevie H wont rest till he finds out! ;D
justyr
Post by justyr on Jun 3, 2013 8:48:23 GMT 1
Yes, could be 33mm. Looking at ebay equivalents, they look very similar. I'll get back to the ('well known in the media' ebay seller). Thanks to all contributors for helping. J
Post by Norbo on Jun 5, 2013 7:16:02 GMT 1
Youll have to put the pics up with phot bucket now sorry the Attachment thing wont work any more
