Post by Roofmonster on May 18, 2013 20:36:00 GMT 1
Has anyone got advice on fitting a LC seat cover. I have never done one before, is it difficult ? should I send it to someone else to do it and if so who? Thanks JC
Post by sidney on May 18, 2013 21:53:56 GMT 1
You will need a bloody good staple gun because the plastic seat bace is really hard , I got a upholsterer to do mine £20 with no hassle
Post by Norbo on May 20, 2013 7:06:26 GMT 1
As above not a hard job but id sooner get some to do it as my staple gun just isnt good anough and they all so use Adhesive as well .
Post by butchers on May 20, 2013 8:46:21 GMT 1
"marsbar" did his own seat cracking job as well. you need a good staple gun as its been said and marsbar "Andy" was very carefull not to pull the cover to tight along the length so to prevent the tail end of the seat curling up at the rear leaving a gap from the underside of seat to the framework. good luck
Post by Roofmonster on May 20, 2013 13:45:41 GMT 1
Thanks guys - Ill pm marsbar and see what staple gun he used - I'm sure the workshop at work needs one .
