Post by rzpauly on May 17, 2013 11:53:13 GMT 1
hi there again guys, just need a bit of help trying to sort the temp gauge not working, to cut a long story short i need to know is the temp gauge( with ignition on) supposed to have 12 volts going to it via the brown wire on the back, the green/red goes to the sensor in the head, checked and working, black to earth yes checked but i dont have any voltage thru that brown wire which splits into 2 on its way to the temp gauge from the headlite and also supplys the oil sensor lite which dosent work either, seems the brown wires supply every thing else horn front brake rear brake taillights etc thanks
