Post by looey on May 2, 2013 17:44:55 GMT 1
What gaskets do people use between the V-Force 3 reed assemby and the barrel on a YPVS, cos the standard metal one doesn't fit over the V-Force reed petals ??. Looks like it used to have paper gaskets there (possibly home-made) but there's none in my full gasket set I just bought ??. Suppose I could make a couple ?. Cheers
matt7
Post by matt7 on May 2, 2013 19:21:07 GMT 1
I trimmed the inner corners off some paper ones, fitted a chariot inlet thingy at the same time, have used paper both sides of vee3 block.
Post by midlifecrisisrd on May 2, 2013 19:45:27 GMT 1
Just checked and my V force 4's came with gaskets that are not metal.
Also think that the last Gen Yam ones I bought are not metal. Probably a Banshee superseded part now.
Pattern kits usually have the metal ones.
Post by looey on May 3, 2013 7:38:55 GMT 1
Cool thanks, I'll make some of my own from gasket sheet I think
Post by Norbo on May 3, 2013 13:23:57 GMT 1
They should come with gaskets
Post by looey on May 3, 2013 17:34:07 GMT 1
Yeah I think they must've from new but I'm rebuilding the top end of mine that already had them fitted and the paper gaskets on there are mullered ;D ;D
