Post by looey on Apr 23, 2013 16:48:47 GMT 1
Post by markhoopy on Apr 23, 2013 19:34:57 GMT 1
Post by looey on Apr 23, 2013 19:51:24 GMT 1
Yeah I saw them when I didn't know I needed any but now they appear to be out of stock
Post by Deleted on Apr 23, 2013 19:57:30 GMT 1
Post by nikfubar on Apr 23, 2013 19:58:29 GMT 1
f**k me that's an ugly mess who's been butchering that Doesn't Norbo sell all the bits you need ? Maybe you could get the barrel welded, personally I would replace it, not good mate
Post by midlifecrisisrd on Apr 23, 2013 20:02:26 GMT 1
You could get that welded but is probably worn.
Was it NK or stan stephens that offered boring it out and fittind a thin bush.
I'll have a look if I have a pair of valves.
Post by Shytalk on Apr 23, 2013 20:13:10 GMT 1
You could get that welded but is probably worn. Was it NK or stan stephens that offered boring it out and fittind a thin bush. I'll have a look if I have a pair of valves. Steve It was Stan
Post by Norbo on Apr 24, 2013 8:24:55 GMT 1
I dont think he has them any more he ran out some tiome back and cant get them made again./
Post by Dieseldog on Apr 24, 2013 12:05:01 GMT 1
You could try plastic metal on the valve ends. Easy to file down and quite strong, might be worth a try as a short term measure.
Post by midlifecrisisrd on Apr 24, 2013 15:00:04 GMT 1
I dont think he has them any more he ran out some tiome back and cant get them made again./ Factory that made them f*cked with the earthquake there. Got them made in US last I heard as that's where my replacements for the sh1t cast ones I got from them came from. As for the crack, just silicone the bush in along with the retainer as the barrel looks like it has a groove worn in it anyway. Stan charges about £30 plus post to re bush I think. Steve
Post by Yogi on Apr 24, 2013 20:28:18 GMT 1
Stan bored my heads 2 months ago and fitted PV bushes?
phil38
Post by phil38 on May 1, 2013 12:50:39 GMT 1
The ends of the valves where they join were the same on mine. I got them built up with weld and then re-machined to fit the (new) clamp. All but one of the bushes were very worn too, and the journals on the valves were worn & oval. Got the journals turned down until they were round and new inner bushes machined from phospher bronze to fit the journals.
Cost a few quid in favours from a bloke at work, but alot less than new parts. I think you can still get most of it from Yamaha, but new values, bushes & seals adds up to about £300!
That crack looks like your biggest problem though....
Post by bare on May 1, 2013 17:12:55 GMT 1
Might be clever to buy decent used barrels... complete with pv bits?? If thats' what the PV area looks like, It's likely the rest ain't great either.
