Post by jon on Apr 21, 2013 19:16:09 GMT 1
Has anyone had experience of fitting a TZR 3XV rear wheel into a YPVS with regards to sprocket alaignment?
I have an RGV swingarm for my YPVS and the 3XV wheel fits very well on the rim and hub width.
However the centre of the wheel to the inside of the rear sprocket is around 98mm.
I have been told with a 10mm offset front sprocket, you should aim for around 88mm from the centre of the wheel to the inside of the sprocket.
Therefore I am thinking a dished sprocket carrier would work well.
Has anyone fitted such a wheel to a YPVS?
Post by jon on Apr 23, 2013 19:54:56 GMT 1
I have found a sprocket off the shelf which would work with a carrier after searching the internet for sprocket dimensions.
I will get a quote on machining a carrier by the end of the week.
Has anyone else done this differently?
