Post by daglad on Apr 18, 2013 10:39:55 GMT 1
Quick question, do you run with a fuel filter?
Post by spencerd on Apr 18, 2013 14:38:28 GMT 1
Quick answer....YES!!
Post by Norbo on Apr 18, 2013 16:36:23 GMT 1
more and more nowdays with bits in the tank
justyr
Post by justyr on Apr 18, 2013 17:21:23 GMT 1
yes, particularly since tanks are getting flaky or have dust in them after paint jobs. Even with a fuel filter in I get fine dust in the float bowls.
Post by skaterboy on Apr 18, 2013 18:16:40 GMT 1
As above yes but still find a fine dust in float bowels when cleaning.
Post by Haggler on Apr 18, 2013 19:50:55 GMT 1
No but drain and clean tank every year but that's just me
Post by Delbert on Apr 18, 2013 20:37:01 GMT 1
Yes i do too but i wouldn't use the tiny ones Why not the tiny ones ?? I use them as they.fit in nicely,, not had a problem to date
Post by winnerevo1 on Apr 18, 2013 21:19:42 GMT 1
Yes i do too but i wouldn't use the tiny ones Why not the tiny ones ?? I use them as they.fit in nicely,, not had a problem to date So there's no chance of restricted fuel flow to the carbs.....
Post by stanlc7189 on Apr 18, 2013 21:44:16 GMT 1
Which ones do people recommend and do fit one in each fuel line or can you get filters with two outlets?
Post by spencerd on Apr 19, 2013 0:12:09 GMT 1
I use an R6 fuel pump & filter so few issues
Post by Tone on Apr 19, 2013 6:48:20 GMT 1
I use one of the disposable ones from the RD LC shop listed under the accessories and tools section on my LC2. I just use one fitted between the fuel tap and T piece. Whenever I strip the carbs they always seem clean with no sediment in the float bowls. Just need to make sure you fit them with the arrow on the filter the way of the fuel flow.
Post by arrow on Apr 19, 2013 15:05:56 GMT 1
I don't use one.
Post by daglad on Apr 19, 2013 22:34:05 GMT 1
Thanks for the replys guys, it seems to be the way to go but..... they just look well, ugly to be safe i will get one (If i ever get the blinking thing finished)
Post by billyboy on Apr 20, 2013 8:08:13 GMT 1
if you use a decent tankliner that copes with ethanol you will never need one , agree with headcotes on small ones ,caused fuel starvation on one of my bikes
Post by looey on Apr 20, 2013 8:47:31 GMT 1
The little ones are fine, they would only restrict flow if they're full of cr*p which you could see if/when they need changing because they are clear plastic.
If you put one of those in-line, then disconnect the line from the carb and open the fuel tap, your tank will empty just as quick as if it wasn't there, so it won't cause any restriction supplying the carbs when running.
I've got them fitted to several bikes here including the tuned YPVS engine and never had a problem.
