Post by Delbert on Mar 11, 2013 20:53:30 GMT 1
Need some help here guys
Out of curiousity I thought I would check the back lash numbers as the casings off , I have 82 on the primary gear but can't see any nos on the clutch gear ,,,
I do have a knackered basket with p/n 1A001Y32. & 65b on the gear The one with no number has p/n 1A001Y22. Any ideas ?? Or just put it back together. & stop faffing
Post by flames on Mar 11, 2013 20:57:47 GMT 1
that last sentence would best describe what i would do. ;-)
Post by ianr4863 on Mar 11, 2013 21:15:18 GMT 1
The 1AO and 01 are the first and last digits of the part no . The other numbers most likely production run numbers . So plus 1 for Flames comment above ;-)
Post by arrow on Mar 11, 2013 22:16:58 GMT 1
Just make sure that when it goes back together that you have a small amount of backlash. If there is non then the gears will run too tight when they get hot as the diameters expand with the heat.
