Post by spondonchris on Feb 20, 2013 11:21:47 GMT 1
Question one, is it possible to change the outer crank seals on a 4L0 engine without splitting the cases ? question two, whats the standard weight fork oil in a 4LO as i am about to fit progressive springs and i may go a little heavier on the oil, all Halfrauds seem to have is 10 weight.
Post by mikee on Feb 20, 2013 11:33:34 GMT 1
Well I suppose you can change the crank seals without splitting the cases , but I don't think it would run after tho Do it proprly , will only take 3or 4 hours at a leisurely pace
Fork oil , bitd we used two stroke oil ,ATF,20/50 ,10/40 and often a mix of the lot I think 10/40 and about 20cc more and 10 2p pieces as pre load , or tap the fork top bungs m8 and fit a bolt and spacer to pre-load the springs ,hey ho adjustable suspension (use a long grub screw if you want to keep it looking stock )
Mike
paulo
Post by paulo on Feb 20, 2013 11:37:42 GMT 1
Hi m8, no for the seals as there is a lip on the seals that sit within a groove in the casings, so not a 5 min job. Fork oil , I've got medium fork oil in mine (15), but I know some people have went up to 20 - all depends on how you ride and what you like - I would go for 15 as it gives you the best of both.
Post by spondonchris on Feb 20, 2013 11:56:38 GMT 1
Thanks for the advice guys, the forks are so soft now its dangerous as im running Fireblade brakes, one improvement throws up another problem haha.
Post by marsbar350 on Feb 20, 2013 15:28:28 GMT 1
done the crankseal on denzils bike last weekend undo the crankcase bolts top and bottom.leaving head and barrels in place.remove bottom half and replace.all in id say a day to do it
Post by spondonturbo on Feb 20, 2013 18:56:23 GMT 1
Spondonchris, I have a load of different weight fork oils here, new never got to use them, let me know what weight you want and I'll see if I have any for you
Post by spondonchris on Feb 20, 2013 19:09:35 GMT 1
Smart dude, you know i never realised you could leave the head and barrels in place, bloody good tip that thanks.
Post by bigal1 on Feb 20, 2013 19:42:37 GMT 1
take the engine apart to do the seals and why its apart check all the inside out
Post by bigal1 on Feb 20, 2013 19:43:57 GMT 1
take the engine apart to do the seals and why its apart check all the inside out if the seals have gone this can some time cause the bearing to wear
Post by ianr4863 on Feb 20, 2013 20:02:24 GMT 1
If it helps I fitted some progressive springs I got from Norbo . 20 oil was terrible so I swapped it for 10 at the weekend . Problem sorted .
Post by spondonchris on Feb 21, 2013 0:34:20 GMT 1
Thanks Ian i will go for 15 weight i think, see how that goes.
