Post by Shytalk on Nov 20, 2012 20:51:39 GMT 1
Post by midlifecrisisrd on Nov 20, 2012 20:53:21 GMT 1
The 1a2 model number was aircooled 250 Ithink
Post by Tone on Nov 20, 2012 22:20:56 GMT 1
As Steve has said the 1A2 00 carbs were fitted to the aircooled RD250C/D model.
Tone
Post by marddy on Nov 21, 2012 18:40:26 GMT 1
It is a air-cooled carb set for C and D models...not an original one for the LCs. Suggest you to use the correct ones as these will take a lot of your time to set up in your LC.
Post by marddy on Nov 21, 2012 18:42:24 GMT 1
And, the carb tops belongs to LCs. So, remove these and use stock ones else your AC throttle cable will not fit in.
Post by Shytalk on Nov 21, 2012 21:15:32 GMT 1
And, the carb tops belongs to LCs. So, remove these and use stock ones else your AC throttle cable will not fit in. Thanks for the information chaps, they are a set that came with some 350 spares so I really wanted to know what they were off. ;D
