Post by daglad on Sept 11, 2012 20:32:08 GMT 1
Very quick question i am fitting the clutch cover gasket tomorrow, do i need gasket goo on it or is it a dry fit. Also, i have noticed on the throttle cable, where the cable splits into 3 the casing has a designed split on the rubber housing, it looks like it should slide onto a bracket but i can't see anything, any thoughts? Oh ye it's a 31K powervalve
Post by Shytalk on Sept 11, 2012 21:08:36 GMT 1
Dry fit, or you can put a smear of grease on it to enable it to be reused if you need to remove it to adjust the clutch.
The throttle cable should fit into a small flat plate can't recall if it points forwards or backwards, but it should be just above the cylinder head area and the rubber slides onto it to keep the joint / cable held in place.
Post by daglad on Sept 11, 2012 22:07:06 GMT 1
Cheers shytalk, i thought it would be a dry fit, I have seen the bracket you refer to for the cable but it just seemed to far forward on the frame, i will have another go tomorrow, watch this space.
