Post by photoman1963 on Sept 10, 2012 22:18:31 GMT 1
I have sanded exhausts and spprayed with BBQ satin black heatpaint, but after 8 hours its still tacky?! I have read that to cure the paint you need to heat up the BBQ afterwards!! difficult with exhausts off bike!! I know members have used this paint.. advice please!!
Post by Deleted on Sept 10, 2012 22:20:00 GMT 1
ive heard people using a hair dryer to speed up the process
Post by daglad on Sept 10, 2012 22:22:34 GMT 1
Which manutacturers paint have you used, I used Plastikote BBQ Satin and it was touch dry within 1 hour
hazey
Post by hazey on Sept 10, 2012 22:28:04 GMT 1
I too use Plastikote bbq paint and had no problems with drying within 1/2 hours,i dont assemble anything until at least the day after just to make sure
Post by davey on Sept 10, 2012 22:44:04 GMT 1
i used bbq paint also and it was dry enough to put em back on in an hour ish. But it doesnt really get the full cure till its got hot then its fine but i did wait a day b4 i ran the bike. i used juliens brand
Post by photoman1963 on Sept 10, 2012 23:01:48 GMT 1
sorry guys it is platicote! nice finish when it's dry, how long do you think it will last?? Shame there is pitting on the top of the manifold inside end on one of the pipes! I also noticed something is loose inside one of the exhausts?? ideas?
Post by daglad on Sept 10, 2012 23:04:03 GMT 1
Check you have a full baffle you never know it might be as simple as that
hazey
Post by hazey on Sept 10, 2012 23:11:34 GMT 1
sorry guys it is platicote! nice finish when it's dry, how long do you think it will last?? Been on my RD400 barrels and heads for 3 years now with now flaking or cracking did some valve exhausts just recently and chap i sold the bike too has had no problems
Post by Denzil on Sept 11, 2012 6:39:15 GMT 1
BBQ plasticoat paint must be cured within 3 hours of application. I did this by leaving a hot air gun pushed in the end of the exhaust and left on for an hour, switching either ends half way through.
Post by Norbo on Sept 11, 2012 9:46:27 GMT 1
What i do is poer boiling water over the pipe then dry of with a towl hang on the line and spray . The heat from the water evaporates anything left on the pipe after a wipe down and after a spray they are dry with in an hour. But after they are fitted and the bike is started up they will go of any way /.
Post by foxyjohn on Sept 11, 2012 12:24:53 GMT 1
Heat the exhaust with a plumers blow torch and apply the paint then when dry bake on with the plumers blow torch ;D if you use this method be careful you do not burn your shed /garage down
Post by photoman1963 on Sept 11, 2012 14:14:24 GMT 1
lol
Post by Bozzy on Sept 11, 2012 18:20:42 GMT 1
Golden rule I found with this stuff is to not put on too many coats. To thick a covering you get bubbles when heated on the bike, which then starts to peel which you then have to cut back and respray which creates patches which then you have to apply thicker to cover .............. found out the hard way....but great if you do it correctly as it says on the tin
higgsy
Post by higgsy on Sept 14, 2012 8:22:45 GMT 1
I have the joys of painting lorry body repairs in the freezing cold occasionally, to get primers to cure we use a hot air gun to heat the body, spray the paint and use the hot air gun in conjunction, sort of spraying both if you know what I mean, works a treat!
As bossy said, thin coat, wait until it's dry then reapply, build up the coating, don't try to do it all in one coat.
phil38
Post by phil38 on Sept 21, 2012 13:02:13 GMT 1
Platikote looks good, did mine with it . My headers were in a state so I used a wire wheel on a drill to remove anything remotley loose - I wen over the whole exh. to to provide a good key.
The Platikote paint is supposed to be cured within or a few hours so I hung the exhaust from some wire and shoved a hot air gun in the inlet and left it there for an hour or so on each
BEWARE IF YOU DO THINS THEY NEED TO BE DECOKED FIRST
If you don't you'll have a garage full of smoke, red hot exhausts an probabaly a fire!
(I decoked mine before I painted them, using the same hot air gun - outside)
drzsimon
Back after a long break
Post by drzsimon on Sept 21, 2012 13:48:04 GMT 1
I tried all the BBQ paints and nothing was durable enough. I found it scratched really easy and was too easy to rub through when polishing the exhausts. So I went for teflon coating These are the pipes as delivered last night I'm super impressed! They still need oiling and running up before I can polish them. Simon
Post by steve h on Sept 21, 2012 18:17:29 GMT 1
You could strap sausages on them and bacon and if theres room some blackpudding and a couple of slices of bread. Hey presto, a cooked breakfast on the arrival at your destination! ;D
Post by Deleted on Sept 21, 2012 22:07:12 GMT 1
I tried all the BBQ paints and nothing was durable enough. I found it scratched really easy and was too easy to rub through when polishing the exhausts. So I went for teflon coating How much did that cost?
drzsimon
Post by drzsimon on Sept 22, 2012 8:42:17 GMT 1
You could strap sausages on them and bacon and if theres room some blackpudding and a couple of slices of bread. Hey presto, a cooked breakfast on the arrival at your destination! ;D I asked how durable is it, he said don't let your lass near them with a spatula Oiled 'em up last night, going to put them on the bike and run it up today to bake them then it's good old quality polish. Even before oiling they had a weird slippery finish, it's different to pan stuff though. I'll put more details in a different thread when I've had chance to evaluate it as it's not cheap Simon
Post by bigal85 on Sept 9, 2013 20:36:08 GMT 1
I just use. Vht paint on my rd exhaust matt finish thought looks ok just start your bike up get them hot. Drys in minutes !!!! Can get it on E bay. Not cheap though ok .........
phil38
Post by phil38 on Sept 10, 2013 12:46:50 GMT 1
The Plastikote is supposed to be cured with 8 hours of painting (I think). I did mine by hanging them up from lengths of wire from the garage ceiling and shoving a hot air gun down the inlet for an hour. Paint started tacky and finished dry and hard.
WARNING!!!
So not do thins unless you have decoked the exhausts before painting as you will set fire you your garage and burn the paint off. De-cokeing can be done very effectively using the same method (but outside, not in the garage!!)
If the bike's a runner, get em on ASAP and go for a ride.
Post by billyboy on Sept 11, 2013 21:56:01 GMT 1
what happens if the paint is NOT cured within 3 hrs? , like say 2 years later lol
Post by Dieseldog on Sept 13, 2013 10:43:49 GMT 1
I tried all the BBQ paints and nothing was durable enough. I found it scratched really easy and was too easy to rub through when polishing the exhausts. So I went for teflon coating These are the pipes as delivered last night I'm super impressed! Where did you get them done?
