Post by snowbound on Aug 25, 2012 19:12:00 GMT 1
My MK1
Around 2004/05 i acquired a Rd 125 LC. It was easy transport at the time to get to work and alot cheaper then getting my car licence.
She was lovely little runner. and the smell of 2 stroke was far too addictive, not to mention the powerband.
I did burn through a set of piston rings, these were replaced and the bike was fine (damn powerband!).
long story short i joined the army and she went into storage.
Just left the army and I'm a little wiser, have my full bike license and understand the issues that the bike had and how i can get her running sweeter than ever.
Specs:
Nikon exhaust
K&N style air filter
6 mm spacer plate on reeds
+1.50 over bore
oil is pre-mix
12a carb with 240 main jet.
Back when i was young(er)
How i get her from Sheffield to Cornwall:
So, down to the nitty gritty.
Was having charging issues, so did all the tests with a multi meter and the conclusion was the stator/alt, bought a working one and came to fitting it and the wires didn't match up with the CDI unit, turns out the CDI and stator were a MK3 on a MK1 loom.
Swapped out the CDI, stator and flywheel out for Mk1's and all is good.
Gave her new fluids and oils and ran her for a week, loving every second of the powerband and the smell of 2 stroke.
Started seeing coolant in the glass window so had to do some more problem solving, resealed water pump and flushed with cheap oil and then put some decent in.
after a 10 mile run the coolant was back in.
Stripped the water pump and took the clutch case off to find this:
i738.photobucket.com/albums/xx27/SnowBoundZero/0A66DF70-04AB-499D-8D9D-B8A114BDC97B-61620-0000033362438025.jpg
New seal fitted, just waiting for the instant gasket to set to see if all is good.
Couple of pics as she stands now:
i738.photobucket.com/albums/xx27/SnowBoundZero/6C9EC955-E586-4CC7-88BF-D127EC624DC2-61620-000003339A988009.jpg
i738.photobucket.com/albums/xx27/SnowBoundZero/1087A088-CB76-46D6-B5F3-0E01FCC20760-61620-00000333828EFCFC.jpg
i738.photobucket.com/albums/xx27/SnowBoundZero/04685983-6612-47BF-9C7B-BA22A44F9058-61620-00000333CA58E44A.jpg
i738.photobucket.com/albums/xx27/SnowBoundZero/D907B138-0E9B-4D09-8EC7-14085AB0EBC9-61620-000003338EDA18F6.jpg
**I've put direct links at the bottom as Photobucket is being slowwwww.
Specs:
Nikon exhaust
+1.50 over bore
oil is pre-mix
