Post by liffy16 on Aug 14, 2012 0:51:12 GMT 1
me again with rd350n1 right hand carbs been flooding out of overflow pipe.stripped all down back together wont start plugs are getting wet,good spark arrgh!so it should start slides are okay, choke pipe in place,only thing i can think of is timing, has woodruff sheared help!
Post by bluebellc on Aug 14, 2012 8:08:36 GMT 1
Tried some new plugs? They'll only stand so much messing about! John.
Post by davey on Aug 14, 2012 8:31:28 GMT 1
Try the heating plugs with a blow lamp method
Post by liffy16 on Aug 14, 2012 10:10:39 GMT 1
have tried heating/drying out plugs on gas stove,will try some new plugs john thanks for feedback
Post by cb250g5 on Aug 14, 2012 10:30:54 GMT 1
Did you strip both carbs?
If so, did you get the float bowls back the right way round?
Post by liffy16 on Aug 14, 2012 13:39:11 GMT 1
yes the bowls are correct l/hand carb for choke righthand carb blanked off,took carbs off again to double check
Post by rdstars on Aug 14, 2012 13:44:12 GMT 1
Also it is possible to get the throttle slides the wrong way. Mine did start with them wrong ( just ) but did not run very well.
Post by liffy16 on Aug 14, 2012 13:48:40 GMT 1
checked slides when putting in and then check again when there fitted by taking out tickover screw you can see bottom of slide
Post by arrow on Aug 14, 2012 14:23:13 GMT 1
checked slides when putting in and then check again when there fitted by taking out tickover screw you can see bottom of slideThe cutaway for the idle screw will always be on the outside even if the slides are in the wrong carbs.
Post by liffy16 on Aug 14, 2012 16:36:02 GMT 1
took exhausts off to check powervalve is working okay pipes full of fuel! could crankcases be full of fuel?
Post by liffy16 on Aug 14, 2012 17:13:33 GMT 1
cracked it!she must have been more flooded than titanic lol ! fixed carb flooding ,keptd taking plugs out heat up on stove,repeat 6 times and she fired up. right i'm going for a blast c u later and thanks for the help chaps
db8888
Post by db8888 on Aug 14, 2012 20:52:57 GMT 1
Hi I Suggest you prime the engine with oil before you ride it all that fuel will have washed the bearings and the bores of oil also check your carbs arent still flooding cheers Dave
