Post by Shytalk on May 31, 2012 14:40:39 GMT 1
I remember seeing part numbers for the shims for the oil pump (350) some time ago. Does anybody have the part numbers please?
Post by Trubrit on May 31, 2012 15:13:06 GMT 1
Hope This Helps......
Post by Shytalk on May 31, 2012 22:23:28 GMT 1
Perfect - thanks ;D
Post by lb on Jun 5, 2012 11:51:23 GMT 1
Pretty sure these are no longer avail.I remember reading (here I think) someone use an old set of feeler gauges,drilled hole into the correct sizes needed to suit pump shaft & ground the outside dia to suit. Bit of mucking around but garranteed to get the sizes you need.
Post by donypvs on Jun 6, 2012 8:50:15 GMT 1
What I did was measure up the gap and then figure out what shim size I needed then made it out of a feeler gauge blade of the correct thickness. Drill a 6 mm hole then fashion into a washer shape. Does not need to be perfectly round as there is plenty of room. Got the pump stroke exactly what I wanted.
Don
Post by Shytalk on Jun 15, 2012 16:04:58 GMT 1
I can confirm that all 3 shim sizes are still available from Yamaha @ £1.17 per shim.
