Post by paul8899 on Mar 2, 2013 18:06:34 GMT 1
Thanks for the comments , it's taking a while to get finished , just hope it's worth the wait !! Here's what the milling fairies left for me this morning Wonder what they've left for me on monday
Post by paul8899 on Mar 7, 2013 19:59:40 GMT 1
Managed to get the mount machined up this week Just hope it fits
Post by flames on Mar 7, 2013 20:07:44 GMT 1
class
Post by kennyroberts on Mar 7, 2013 20:47:11 GMT 1
loving those milling faries.!!!,
Post by paul8899 on Mar 10, 2013 17:20:26 GMT 1
I managed to sneak out into the shed today and I found that the 2 mounts were slightly out of line . So I spent an hour armed with a dremel and a file and I ended up with this :smt001 There's a couple of jobs to do before it's perfect , got to increase the clearance where the top engine mount goes by 5mm and there's a small section of the frame that needs clearing for the bolt but apart from that it looks good so far Once I've done these jobs I can then make a start on the stabiliser plate , ooops , meant bars
Post by nitronik on Mar 28, 2013 2:22:31 GMT 1
Those parts you have made are a real credit to you.
Post by daglad on Apr 11, 2013 19:52:24 GMT 1
this is a cracking build mate, can't wait for more pics
Post by paul8899 on Apr 11, 2013 20:20:49 GMT 1
this is a cracking build mate, can't wait for more pics And so it shall be ....... I was sitting in the shed the other day wondering what the hell I had started when I noticed that the engine was sitting a bit low and the gap round the top of the cases looked a bit big , so I decided on making another rear mount. With my trusty tape measure I precisely measured it and settled on 20mm , I then set about sitting in front of my pc for hours waiting for inspiration and I ended up with this As you might of noticed I had to remake the mount completely as one of the joys of making parts out of solid is that if it needs modifying it means making it from scratch , so I now have a rather posh doorstop as well Over the weekend I managed to get the Mrs and kids to leave me in peace for a few hours so I thought I'd take advantage and try the mount out , which ended up with this There is a small problem in that the back of the engine mounts foul the frame mount so I'm going to have to machine a clearance pocket into it to allow the engine to rotate a bit as the side cases won't fit as it is. I had to do a bit of surgery on the frame spar so the bolts would go in I'm going to turn some tubes up and get them welded in place once I tidied the cut out up a bit. This now means I can get rid of the cradle that was fitted to the bike when I bought it
Post by fatfastroger on Apr 14, 2013 9:07:28 GMT 1
Looks so much nicer without that awful cradle, great work keep it going
Post by Norbo on Apr 15, 2013 7:17:02 GMT 1
I realy love to big lumps of masheened alloy like that . Its gowing to be sooper cool this build .
Post by paul8899 on Apr 22, 2013 23:08:09 GMT 1
I decided that I'd have a go at setting the swingarm angle over the weekend and after a bit of messing around it now looks like this Once the tyres are fitted it will raise the bike up another 75mm so all going well there will be plenty of room for the exhausts , if not I'll have to look into moving the linkage out of the way , which is something I'd rather not do as it will make it even more complicated ! I had a bit of spare time and after a couple of hours on the mill I ended up with this I had to re-make the bottom yoke because the first one didn't have any clearance at the back for the wiring to pass through so I angled the back face off instead of having pockets. The brass shim is there because the forks I'm rebuilding are 54mm and the Gsxr ones I'm using now are 53mm so once I've had them rebuilt they "should" drop straight in . Next update might take a while as I'm trying to get my head around how to make the front engine mounts and if I'm honest it's not going that smoothly !
Post by tigermac on Apr 27, 2013 10:31:44 GMT 1
Work of art in the making!
Post by paul8899 on May 3, 2013 14:12:11 GMT 1
I finally had these taken apart I checked the sliders and they are nice and straight but after looking at the stanchions they are quite marked and I know I wouldn't be happy with them so ........... You'll notice that there isn't a computer in sight
Post by lb on May 3, 2013 14:28:31 GMT 1
Stunning worrk Paul! The stanchions,these have just been skimmed yes?Whats the plan for finish,polished or paint?
Post by paul8899 on May 3, 2013 14:56:34 GMT 1
Stunning worrk Paul! The stanchions,these have just been skimmed yes?Whats the plan for finish,polished or paint? Thanks , glad you like it so far. No , they are new stanchions I've got the hole in the middle to do yet I'm going to get them anodised , not sure on the colour yet though
Post by Norbo on May 3, 2013 15:00:17 GMT 1
Holly crap i thourght you were just taking of the outer skin from the gold ones.
Post by paul8899 on May 3, 2013 15:10:37 GMT 1
Holly crap i thourght you were just taking of the outer skin from the gold ones. I did think about tarting the old ones up and getting them stripped but I couldn't help myself
Post by lb on May 4, 2013 4:24:13 GMT 1
Ditto on the wow! Thats a big boring job. Using a bar or big assed replacable tipdrill? Also,the engine cradle. Is there a front mount or the rear one you made handles all of it? Now that blingy door stop.......would that fit a 2ma frame? :-)
Post by paul8899 on May 4, 2013 17:33:12 GMT 1
Ditto on the wow! Thats a big boring job. Using a bar or big assed replacable tipdrill? Also,the engine cradle. Is there a front mount or the rear one you made handles all of it? Now that blingy door stop.......would that fit a 2ma frame? :-) There's only 2 sections that need boring , where the front bush and oil seal are and the top bush . The rest is clearance , once I've cut one of the ohlins legs in half I'll post some pictures up The plan is to have front mounts but I've stopped that for the time being , which might explain why I never seem to get anything finished I'm not sure if it would fit a 2ma but I'm sure I could come up with something
Post by paul8899 on May 25, 2013 15:41:42 GMT 1
Managed to find a couple of hours spare and I ended up with this pile of bits ( mine are the bits on the right ) I had a test fit of the sliders and there's a bit of play but when the legs get anodised that will get taken up , I hope ! I've still got to put the rebound screws in and the key ways into the preload adjusters and then I think they are ready to get put together , well unless I find something else to make for them , just can't think of what though :eusa_whistle: I know the finish on this part isn't that important but .... It's not as if it's that difficult to get a good finish , here's my effort
Post by subaru180 on May 25, 2013 18:54:52 GMT 1
I have just gone through this post and all i can say is wow!! The work you do and have done is fantastic!! Cant wait to see the final result!! Keep it going.
Post by fatfastroger on Jun 6, 2013 21:18:42 GMT 1
you're taking this to a higher level than I have ever seen, engine mounts and yokes aside but FORKS !!!!!! top job
Post by paul8899 on Jun 13, 2013 20:18:40 GMT 1
Just a small update , I got the new fork legs from the anodisers today and they only bloody well fit
matt7
Post by matt7 on Jun 13, 2013 21:08:58 GMT 1
Wow, wow & more wow
Post by copper99 on Jun 14, 2013 20:01:32 GMT 1
Beautiful work mate...
Post by paul8899 on Jun 18, 2013 19:52:10 GMT 1
Thanks , I'm really pleased ( relieved ) that they ( seem ) to fit , it's going to take a while before they are built up and tested though Got the replacement tops back today Just have to make the rebound screws and a couple of other parts and they are ready to get rebuilt , or binned !
Post by jmartin on Jul 19, 2013 22:56:50 GMT 1
Some real nice work there
Post by kevsypvs on Jul 20, 2013 10:56:45 GMT 1
totally amazing work there mate ,mindblowing machinework too
Post by flames on Jul 20, 2013 11:05:05 GMT 1
you sir,are wayyyyyyy tooo talented.you need to bag some of that talent up,and share it with us mere mortals.
Post by turbopresh on Jul 20, 2013 20:51:44 GMT 1
here paul.. back in your shed grease monkey! mate of mine has one of these tzr125s i think he's looking rid of might have to pick it up and see if i can get mine finished first
