bigmac
Post by bigmac on May 8, 2012 16:21:36 GMT 1
quick question on exhausts. I have a stock 250lc 4L1. It's running stock 350lc exhausts (the later ones with the thick collar at the manifold joint). Is this a reasonable thing to do or will it affect the performance for better or for worse?
Post by arrow on May 8, 2012 16:49:10 GMT 1
It might affect the low down power a little. I was running 250 pipes on the 350 and it ran well in the mid range, but ran out of steam a bit when you gave it big hand fulls. You might want to go up one size on the main jet, (and check the plug colour) but other than that I don't see it being a problem.
Post by arrow on May 8, 2012 16:50:27 GMT 1
You could also do a swap with someone on here if they have the other problem. How do you know for sure they are 350 pipes ?
