Post by ducatidave on May 2, 2012 10:23:18 GMT 1
Hi can anybody advise on wich 2 get Also i have 2 tanks would treatment do 2 ? Only slight surface rust at bottom of tanks Thanks
Post by midlifecrisisrd on May 2, 2012 13:14:03 GMT 1
Hi,
Have used Por 15 with no problems. You can use the "Marine Clean" and "Metal Ready" parts on more than one tank and the sealer has over half left after draining but not sure how fast it goes off.
Only thing is if you are ever going to sell either there is a stigma over sealed tanks in case they are rotten or the liner fails.
Post by ducatidave on May 2, 2012 13:21:52 GMT 1
Yes i c Dont think i would ever sell but dont want make um worth less Might just keep 1 am usein topt up with petrol and 2nd 1 with just abit ov 2stroke and shake every whk lol Thanx midlifecrisisrd
Post by midlifecrisisrd on May 2, 2012 13:25:18 GMT 1
Yes i c Dont think i would ever sell but dont want make um worth less Might just keep 1 am usein topt up with petrol and 2nd 1 with just abit ov 2stroke and shake every whk lol Thanx midlifecrisisrd Get some vinegar in it to clean out then iol it. Steve
Post by gerumgoin on May 2, 2012 14:38:20 GMT 1
yep get the vinegar in it,cheap at mackro,ive done a few with it,leave it a few days remove vinegar,then filter it and put back in,worked wonders on mine. ;D
Post by ducatidave on May 3, 2012 12:21:58 GMT 1
Thanks gerumgoin will do that
Post by LC_BOTT on May 3, 2012 16:51:08 GMT 1
I just bought some cheap coke (the liquid type to do the same thing, is vinegar any better, or could I mix both together?
Post by flames on May 4, 2012 8:22:27 GMT 1
ive heard vinegar is good but you have to flush tank well after or it will keep eating away at the metal? apparently diesel neutralises it.also heard you can use baking soda/water to neutralise,but also heard it needs to be treated after aswell.seems it depends who you talk to as to the best method.
Post by midlifecrisisrd on May 4, 2012 8:39:05 GMT 1
Problem with the acid route is that the metal has a protective layer which is why it rusts in patches as it breaks down. When this is removed the surface will flash rust quickly, hence why I por 15'd my other tank after removing the surface rust.
Now no one will buy it as they automatically thing it is a sealed rotten tank.
Post by flames on May 4, 2012 8:39:32 GMT 1
heres a link...http://www.mopedarmy.com/wiki/Removing_rust_from_a_gas_tank.....ok maybe not in the way it should be,but you can copy and paste.on the coke side,it says it needs to be diet coke because of the lack of sugar.
Post by gerumgoin on May 4, 2012 21:27:51 GMT 1
Np and do what was said about making sure its well cleaned out,i spent money on a full tank of petrol and did the same process,fill up leave it a few days and then filter the petrol and put back in, keep doing until your happy,i found that the best method to filter was coffee filter papers.
Post by mellow on May 5, 2012 14:06:56 GMT 1
i really wouldnt recommend petseal m8
Post by midlifecrisisrd on May 5, 2012 20:01:06 GMT 1
i really wouldnt recommend petseal m8 either would i. if youwant it done for you there is usually an ad for new sealer in the back of practical sportsbikes that is supposed to be ethanol resistant. steve
Post by 47x on May 5, 2012 20:34:45 GMT 1
REMEMBER to use white vinegar,the brown stuff leaves a mess!!!!
