Post by aaron on Apr 24, 2012 23:18:54 GMT 1
I have a very slight leak at the gear selector shift seal. How easy is this to replace? I hope I don't have to split the cases open to access
Post by nikfubar on Apr 25, 2012 19:14:39 GMT 1
Easy to replace, just pop it out with a screwdriver & push in a new one, if that doesn't stop the leak then you may find there is a groove in the gear change shaft & to replace this you only need to remove the R/H engine case, if that doesn't stop the leak the gear change shaft bush may be worn out & to change that you need to split the cases
Post by aaron on Apr 25, 2012 19:55:01 GMT 1
Thanks for that do you happen to know what the seal is called or how I would find one?
Post by oldelsieboy on Apr 25, 2012 20:02:43 GMT 1
Thanks for that do you happen to know what the seal is called or how I would find one? Phone you local Yam spares dept and ask if they have part number 93101-12004 in stock. OEB
Post by rich on May 1, 2012 18:47:30 GMT 1
I reckon you could just about replace the bush without splitting the cases using a long drift from the clutch side.
Post by midlifecrisisrd on May 1, 2012 19:28:00 GMT 1
I reckon you could just about replace the bush without splitting the cases using a long drift from the clutch side. If I remember right the shift shaft goes through a section of the case that is separate from the rest so could be knocked in and won't go anywhere. Either that or if you get a hollow drift just knock it in over the shaft with the new one. ( obviously change the shaft first if grooved ) Steve
Post by aaron on May 1, 2012 19:45:10 GMT 1
Must have a wee look at the weekend.
