Post by dave350 on Apr 20, 2012 9:22:53 GMT 1
Anyone know how to convert a 31k to vgv clocks? or tzr 250/n2 clocks, my 31k has cable drive for rev counter. Do i need to change the ecu?
Post by midlifecrisisrd on Apr 20, 2012 15:03:00 GMT 1
Hi, TZR/N2 clocks the easiest, done it about a dozen times. No need to change the cdi, just fit the lc2 loom to the clocks with a few changes. For the tacho you will need to run an extra wire to the Black/yellow at the 29k50 CDI Next problem is the kidney clocks having 2 indicator warnings and the N only one. I fitted 2 led's behind the one light but have since been informed if you ditch the commons from the 2 lights and simply connect the 2 feeds to one lamp it will work. Worst bit is finding and paying for an N2 clock/headlight bracket. Fitting rgv clocks will be a pain as the tacho works on a different principle so you need a box of electronics to run it. A few examples I've done different ways Lc clocks are easily converted, use the cable tacho and can be bolted under the top yoke. Steve Steve
Post by dave350 on Apr 20, 2012 15:58:06 GMT 1
Many thanks! I think I'll go with tzr/n2 clocks as they look the best, but most£££!!! But now I know how! Cheers, Dave.
